Question about Whirlpool Heating & Cooling
RE: Whirlpool hot water tank. FG1F4040S3NOV The pilot light went out and we cannot get it to light again. I was just told there was a recall on the thermocupler. How do I found out if this is the one that is recalled and how do I get one. I am pregnant and I need hot water now!
Master_Tech
  • 770 Answers
SOURCE: i have a whirlpool natural
is it a standing pilot? or Spark ing. model? if standing pilot you will need to replace the Thermocouple if spark you will need to replace the spark box
Posted on May 11, 2008
  • 57 Answers
SOURCE: How do I find out
Quickest way is to call Whirlpool, give the serial # and they can give you the Manufacture date. Sometimes its on the Information tag. But most of the time it's in the serial number in code.
Posted on May 16, 2008
  • 44 Answers
SOURCE: Pilot went out and wont re lite
hi there i come from the uk, but it sounds to me as though it maynot be a thermocouple as if it was the pilot would light when you held it in & go out when you let it go.
it seems to me as though the pilot injector could be blocked no gas getting through to it ? or possibly there is a break in the insulation of the igniter so that when you try & light it it just earths out to the heaters metalwork.
These are just a few ideas that might shed some light on your problem?
Kindly
Richie
Posted on Dec 15, 2008
meBNme
  • 334 Answers
SOURCE: we have a whirlpool hotwater
Fear not, unless you havewater leaking from the tank you won't have to worry with replacing it.
Heres how your heaters ignition system works.
The Pilot is lit, and the flame sensor detects flame and sends signal to the gas valve.The gas valve then sends gas to the burners and the burnes ignite.
If the gas valve does not recieve signal from the sensor it will not come on and it will shut off all gas to the pilot, and burners to prevent raw gas from dumping into your home.
If your system has a thermocouple, 99% change the problem is the thermocouple.
When I service a customers unit, I automatically replace the thermocouple because they are so notoirus for going bad.
You can buy one at Lowes for less than 10 bucks.
To locate the thermocouple, go to the gas valve, fint the small copper tube (about as thick as a pencil lead) and follow it to the pilot. The sensor will be slightly larger in diameter and about 2 to 3 inches long.
You can try cleaning the sensor with steel wool, but usully they just need to be replaced.
To replace it, turn off the gas, unscrew the nut holding the tube in the gas valve, and disconnect the sensor from the ignitor/pilot assembly. Make sure your new T-couple is long enough, as the come in different lengths, you can simply coil the extra length up out of the way near the gas valve.
Install the new one as you removed the old one.
Relight pilot, be sure to hold the button down long enough, and enjoy your hot shower!
If you have any other problems, let me know, and I will be glad to help you.
Please don't forget to rate this solution.
Posted on Dec 26, 2008
  • 234 Answers
SOURCE: whirlpool water heater pilot light does not stay lite
I think you have a warranty on this heater for one year.I call lowes and tell them you are dissatfield with this heater.They will someone to fix it change it out for you. But you have to stand your ground with it.But ithink your prosble is the reset on the heating element.I think it getting to hot and cut it off.Or the thermostate is sticking.Good Luck!
Posted on Mar 15, 2009
WHY WON'T HOT WATER TANK IGNITER WON'T SPARK
In a typical gas hot water heater, the igniter glows to heat a thermocouple which opens the gas valve. There is no "spark" involved. Depending upon how faint the glow is, the thermocouple may not be heating sufficiently and may have to be replaced.
Jul 28, 2014 | Whirlpool Water Heaters
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
I have a Rheem PG50T9A gas hot water heater. We had hot water this morning. When I came home the pilot light was out and won't stay lit. Any ideas?
Hopefully just the thermocouple. The thermocouple is the small rod right next to the pilot light. The flame on the pilot heats up the thermocouple and keeps the gas valve on. You can replace it yourself. The thermocouple will be connect by a small nut on the underneath side of the valve, and you will have to pull the thermocouple out of the pilot assembly. Not an expensive part, you can get it at any hardware store. Hope this helps you .
Apr 21, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Whirlpool Water Heater problem model FG1F4040S3NOV.
I will bet that it has to do with the gas. Probably not breathing right. First check to see if you have the right water heater; inside or outside. Call the manufacturer and have the model and serial number ready. If it is the right one, make sure that it is vented properly, both intake and exhaust. The intake is located on the bottom, probably covered by a plastic screen, make sure that it is clean. Won't hurt to vacuum the immediate area. If it is in a closed off space, it needs to have sufficient enough air to breathe. There needs to be a vent through the door or wall. If this does not solve the problem, have a qualified technician pull the burner out and clean it.
Mar 21, 2010 | Water Heaters
My hot water tanks pilot light turns off after I have relit it. It stayed on while heating the water in the tank and once it stopped heating the pilot light went out again. What would be causing my...
are you holding button down long enough for thermal coupler to warm up? after pilot lights up, don't immediately let go of button for about 15 to 20 seconds then let go and pilot should stay on. If not, you may need a new thermal coupler for that water heater
Jul 03, 2009 | Water Heaters
Whirlpool water heater pilot light does not stay lite
Mar 14, 2009 | Water Heaters
This is a new whirlpool hot water heater.Pilot lights, burner fires, water heats up to temp. burner and pilot both shut down. Unit has to be started manually each time
LP OR NAT GAS , IF IT IS LP CHECK GAS PRESSURE @ TANK AND MAKE SURE NOT TO HIGH , IF NAT STILL COULD BE THE PROBLEM HAVE THE GAS COMPANY CK PRESSURE
Feb 22, 2009 | General Electric GE SmartWater Household...
Kindly
Richie
Dec 15, 2008 | Water Heaters
Heating & Cooling Logo
110 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
