Cool air but not cold - Heating & Cooling
    President:
  • 3,773 Answers
Check compressor. You must be able to hold your hand on it without getting burned if it is too hot then the condenser stopped up
which affects freon flow
I would condemm it if thats the case.
Check Condensor air flow and temp out back.
Both coils may need cleaning.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 07, 2010
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Dec 30, 2010 | Heating & Cooling
Heat is not working. Just blowing cold air no matter the setting
is the "cold air" just room temperature air. put it on cooling and see if its colder than the air that is coming out of it when its on heating leave it on for a few mins make sure its cooling to.. it could be the reversing valve not pulling it onto heating if it can cool and not heat.
if its not cooling or heating it could be a few different problems. gas leak ,pcb boards ect.
Nov 09, 2010 | Amana PTH123B35AE Air Conditioner
What's the difference between dry and cool setting and when should dry be used
Dry is a dehumidifier option. There is a heating element in the unit to heat the cold air back up. The cold evaporator coil causes the moisture in the air to condense on the coil (this is why the AC leaks water) and the air coming out of the vents will be cold. If you are not wanting to lower the temperature in the room but want to take out the moisture then use DRY. All ACs take the moisture out of the air when they are on COOL. So, COOL drys the air and makes it cold. DRY drys the air but warms it back up before sending it out the vents.
Jun 14, 2010 | LG LWHD2500ER Wall/Window Air Conditioner
My central air conditioner is not working properly. It doesn't get cold. All it does is cool air comes out and the house doesn't get cold. What do I do?
well how cool is cool check temp at one of the register should be around 54 degrees. if so you other problems
Jun 26, 2009 | Heating & Cooling
Dometic air conditioner not blowing cold air.
make sure fan on auto if ok and unit on cool check compressor coming on if ok bad cooling unit
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
No cool air when idling..
The refrigerant level may still be to low or the compressor is not working properly.
Sep 02, 2008 | 1996 GMC Sonoma
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
