Question about Boating
Perkins prima m80t .My injectors have failed for the 2nd time in 100hours the report says dirty fuel again but why is dirt or diesel bug getting through my filters which are changed regularly. This has only happened since I have started using star tron additive
  • 1118 Answers
SOURCE: cannot get 1987 chevy van 20 to keep running... stalls out
Best do a fuel pressure test. Should have chg. fuel filter from the get go. The only other filter is on the end of the fuel pump in tank. Bad gas and dirty gas will plug up fuel filter, hense burn pump up.
Posted on Apr 11, 2009
  • 7 Answers
SOURCE: 99 ram diesel wont start
Did you check to see if there is power to the glow plugs if not then that may be the problem and if there is power when you cycle the key not to start but for the plugs to warm up you may have a bad glow plugs.
Posted on Apr 22, 2009
MNfisherman
  • 11896 Answers
SOURCE: 1986 goldwing misfires when accelerating in 2nd gear
The best thing to do is to completely remove and dismantle carbs, and soak insolvent for couple hours then blow dry with air. Replace fuel filter. And check screen in fuel tank. Check for good spark. If weak, check coil and stator voltage
Posted on Sep 12, 2009
  • 28 Answers
SOURCE: WONT START
i have a 96 2500 and i have found that if both batteries are not hooked up with a really good connection that the fuel shut off relay will not engage . it will just crank and crank with no start. it is located on the driver side of engine just about the center of the engine .its round and has a chrome rod coming out the bottom of it .it is mounted with the rod on the bottom .you can move it by hand but it will not lock in place unless you have the ignition switch in the start position. there is a couple of relays for it mounted on the fire wall .hope this helps someone
Posted on Dec 08, 2009
SOURCE: 2004 dodge 3500 cummins diesel sometimes hesitates then dies
My 2004 had the same issue and i replaced the transfer pump. It started right up and ran fine until the next morning i was driving it stalled. Now it won't start up not even with starting fluid.
Posted on Feb 22, 2010
What's your question?nissan caravan zd30 tdd diesel hardstating when cold change prima and heater plugs .what could the problem
cranking speed to slow--cannot generate enough compression heat to ignite fuel
faulty injector tips ---squirting and not atomizing--have an accredited diesel specialist shop recon the injectors
worn engine---compression pressure too low -- have a compression test done
if common rail diesel ---fuel pressure too low to work the injectors properly-- have an accredited diesel special shop test the pump pressure -- should be around 22.000 to 25.000 psi
Apr 05, 2016 | Cars & Trucks
Why woun't my 6500 ransond generator start its a diesel
See id it is actually pumping fuel and if so see if the glow plugs are getting hot.
Oct 07, 2014 | Cars & Trucks
Generator wont start up unless i spray starter fluid into it
This sounds like a dirty carbureator. Just bad enough that it won't start cold.
Mar 29, 2014 | Electrical Supplies
Hi i have a 2006 dodge diesel that we figure got bad fuel and stopped running.wouldnt start took it in go a new lift pump, fuel filter, lines cleaned and tank cleaned out and its still not running great....
Diesels need to be clean and typically after 10,000 miles removing the fuel filter produces very little in the way of dirt and grit.
You had the tank and lines cleaned out and a new pump and presumably a new filter and still you find dirt and grit in the filter after a short time. ..
Either the tank, etc. wasn't cleaned out or more dirt has entered the tank since, either from more dirty fuel, from dirt ingress into the tank while the car is in use or the third possibility is something is wearing rapidly and the dirt is appearing in the tank to be recirculated after being sent along the fuel return line. If this is what is happening it throws suspicion onto the high pressure pump...
If the high pressure pump is failing it is surprising one or more of the injectors hasn't failed.
If you got dirty fuel the filter should have trapped everything that was likely to damage the injection system until performance reduced and eventually the engine stopped due to fuel starvation. Replacing the fuel filter with a suitable amount of care should then restore performance to the previous level.
Fuel filters are great for trapping dirt but not so good for other liquid contaminants. Water fortunately tends to remain at the bottom of the tank and the bottom of the filter cavity but other things might pass through the filter - acids, salt solution, solvents.
A couple of years ago there was a case of a few petrol filling stations selling fuel contaminated with seawater and shortly afterwards a lot of injectors needed replacing...
I think if my car had the problem your car has I would temporarily fit an inline filter to the fuel return line and drive it for a time. Two things should happen if the dirt is self-generated. The new inline fiter when cut open should show the dirt and grit you usually discover in the main filter and secondly, there should be a reduction in the amount of dirt and grit you find in the main filter, however any dirt at all in the inline fiter means my best advice is to take the car to a good diesel specialist for proper diagnosis and a guaranteed repair.
If dirt is found in the fuel return line there can be no half measures - the business end of the injection system needs surgical-level cleanliness.
May 12, 2017 | Dodge Ram 1500 Cars & Trucks
The gent set is Perkins 135 KVA after overhauled it refuses to start please the injector refuses to supply fuel to the nozzle
Check the fuel solenoid is getting power. It may be locked out by loow lube oil pressure and other things.
ALSO when restarting a diesel one OFTEN must "bleed" the fuel lines at each injector... same as when one inadvertently runs a diesel out of fuel. Crack the connectors at the injectors and crank till fuel comes out and tighten each one. Yes, it is a pain...
Apr 21, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Low power
Hi ,
firstly i would do a full service on it , all filter and fluids , oil/coolant water,fuel filter(s) and air filters
pay attention to any water seperators , check all fuel line connectors and unions are tight and in good order ( drawing a small amount of air into the fuel system if often the cause of ''a lack of power '')
check your diesel as it absorbs moisture and can severley effect the running of an engine .
if this has no effect
get a rag /goggles and the right size open ended spanner and slacken each fuel injector nut whilst the engine is running , listen for the engine noise going down , if it dosent this means the injector is deffective ( might need replacing or cleaning ) do this to each injector in turn , be very careful as you do this , the diesel is at 200bar pressure and can injected you ( hence the rag )
a final one is the fuel lift pump may be deffective , they often partially work and starve the engine at maximum revs , depending on your engine this will be an electric one or driven directly from the engine block , just follow the fuel lines from your diesel tank ,.
hope this helps
Jan 17, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
SANDERSON TELEPORTER, HOW DO I BLEED THE LUCAS FUEL PUMP ON A PERKINS ENGINE
Perkins is a hard engine to prime. Fill the fuel filter with clean diesel, there should be a hand pump on the left side(looking at the front of the vehicle) . There should be a bleed screw on top of the filter housing. Loosen the bleed srew and pump the hand pump untill you get a steady stream of fuel from it. Tighten the bleed screw. Loosen the injector bonnet nuts approximately 1 1/2 turns on all of the injectors. Turn the engine over until you see a steady stream of fuel from the the injector bonnets. Tighten the bonnet nuts, pump the handpump approx 10 times and start the engine. Give it half throttle until it stops stumbling and all of the air is worked out of the system.
Jan 08, 2010 | 1985 Mitsubishi Pickup
Diesel mixed with oil in the sump
You run again the generator but before running, check & mark the oil level. Then stop the generator & wait until the oil settle to the bottom of oil pan. Check the oil level again & if the oil level is higher than the marking before that's means you have an engine gasket leak.You need to replace that gasket.
Mar 19, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Diesel fuel pump/installation
If we're talking about the thing that has a pipe to each of the cylinders on your engine then the answer is Yes, your injector pump must be correctly timed in order for the engine to run properly. This is the part of the diesel that does what a distributor on regular car engine does, namely ignition timing.
The exact procedure for setting the timing depends on what model of engine you have, get a manual from Perkins to be sure.
That said it usually goes like this:
1 - make sure the engine has the correct cylinder at TDC, this makes the gear connected to the camshaft be in the correct position.
2 - Set the pump at the correct position, this will either involve looking at a mark in a window on the pump (standyne pumps), or looking at the keyway in the shaft of the pump, etc.
3 - Bolt the pump into place on the engine making sure the gears/drive meshes nicely. Connect all the fuel lines to the pump.
4 - purge the injectors by loosening each fuel line at the cylinder end and cranking the engine until fuel comes out of the pipe, then tighten it back up.
5 - Crank the engine and start it, check the rpm.
Rank this answer if it helped,
Carl
Sep 26, 2008 | Welding Tools
Boating Logo
156 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
