Question about Nintendo Spectrobes Origins for Wii
Help! I cannot safely use the Cosmo Menu (and therefore change weapons) without my having my game freeze! I unlocked the card input device for Spectrobes: Origins for the Wii and entered in every code for the Spectrobes and weapons/items into my game prior to exploring the planet Slayso. I used the save point right before beating the boss a second time to save Scout and the next time I turned on my game and tried to use the Cosmo menu, it froze upon closing! The music still played and I could see the characters, just the Cosmo menu's white "doors" closed and never opened up again! I have to do a manual reboot via the wiimote to continue from the last save point. I tried leaving the game alone for 30 min with the frozen screen to see if it would solve itself; I tried pushing any/all buttons while on the frozen screen, I also tried accessing the Menu via the 2 button during a battle, all to no avail... The game is still playable, it's just much more difficult w/o the use of the Cosmo Menu since I am now stuck with the Giga Axe S.
my3angels
  • 125 Answers
SOURCE: System Lockup
Best bet is to contact Ninendo Tech Support at 1-800-255-3700. Hope you figure it out!
Posted on Sep 02, 2008
SOURCE: Getting Error Message during game play.
There is a guide that you can get that will solve all errors like this and black screens it has been a lifesaver for me. Have a look at http://www.freegamesforwii.info/?cat=11 they have info on where to get this guide. I cant remeber the site off the top of my head,.
Hope this helps
Posted on Mar 09, 2009
SOURCE: Can't access SDHC card with Rockband 2
Also, I think it's worse than just not being able to use SDHC cards with Rock Band 2 - we can only use SD cards up to a 2 GB max. Anything beyond a 2GB SD card, or any SDHC card, will not work with the games architecture and will be disabled. I bought a 4GB SDHC card for storing DLed music as well, and looked in to the matter when it didn't work. Bummer for us.
Posted on Dec 28, 2009
JonnieC
  • 139 Answers
SOURCE: since we got wii sports resort with motion plus we
i thnk you just need to do a system update and that should rectify this.....it happened me too and this solved it
Posted on Jan 01, 2010
SOURCE: Using the Wii Wheel, uncontrollable
I have the same problem, it's not he remote since it happens with both my remotes. I thought it may be a battery problem but nope. And it started infrequently and is getting worse by the day.
Posted on Feb 20, 2010
Reset parental password
  1. Select the System Settings icon from the HOME Menu, and tap "Open."
  2. Tap "Parental Controls."
  3. Tap "Change."
  4. Input the PIN that was created during the initial set-up and tap "OK."
  5. Tap "Clear Settings."
  6. Tap "Delete."
Dec 01, 2013 | Nintendo 3ds Handheld Game Console- Cosmo...
Removing encryption key
To open a locked memory card, select Options > Unlock memory card. Enter the password.
If you cannot recall the password to unlock a locked
memory card, you may reformat the card, in which case
the card is unlocked and password removed.
Formatting a memory card destroys all data stored on
the card.
Encryption
Select Menu > Tools > Encryption.
Encrypt your device or memory card to prevent
outsiders from accessing your important information.
Encrypt device memory or memory card
To encrypt the device memory,
select phone memory.
To encrypt the memory card, select memory card from the following:
Encrypt without saving key
• memory card without saving the encryption key. If
you select this option, you cannot use the memory
card in other devices, and if you restore factory
settings, you cannot decrypt the memory card.
Encrypt and save key
• and save the key manually in the default folder. For
security, store the key to a safe place outside the
device. For example, you can send the key to your
computer. Enter a pass phrase for the key and a
name for the key file. The pass phrase should be long
and complex.
Encrypt with restored key - Encrypt the memory
• card with a key you have received. Select the key file,
and enter the pass phrase
Oct 19, 2013 | Nokia E63 Cell Phone
WRITE PRTECTION IS ENABLED ON SD CARD
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 23, 2012 | Nintendo 3ds Handheld Game Console- Cosmo...
Touch screen stuck 3ds wont turn off
If the 3DS ever freezes up on you (it's happened to me a few times now), press and hold the power button for about 10-15 seconds, it should force it to cut the power entirely without requiring you to touch the touchscreen.
Aug 22, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
Lock the A/V ports
Yes you can, you have three diferent lock options:
'channel' this option allows you to lock or unlock particular channels.
'program' this option allows you to lockout a particular TV show.
'game' this option allows you to lock channel 3 and channel 4 plus the external inputs.
To activate the game lock on the tv you need to press the 'menu' key then press the down arrow till you get to 'lock' and press ok.You will then be asked to input a password, if it is the first time you have used the password then you will need to input a code of your choice twice to register it (write the password down and put it somewhere safe) Then you will be in the 'lock' menu so using the down arrow go to 'menu' and select it then se it to 'custom' you will then be able to select the 'game' option by arrowing down to 'game' and select it so that it shows 'on'. Your tv should now have locked out the external inputs etc. To unlock it you go through this procedure again just this time you select so it shows 'off' You can also select 'custom' in 'game' mode which will allow you to select which external inputs to lock which is useful if you have DVD players or other devices connected to your TV and is something for you to consider. Full details of above procedure are in the user manual page 32 - 33 under the heading Lock.
I hope this answers your question.
Regards,
James
Ps. Tell the kids it's my fault they can't play their games!!!!
Apr 23, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Problem using unlocked weapons on Cabelas Big Game Hunter 2010
You have to go to mission select and select a mission. When your on the mission screen to see what animal you are going to hunt hit c. After you hit c pictures of guns with their name on it will pop up. If you have unlocked guns you will see arrows hit them to see all your guns. Pick your gun and that gun will replace your other. Such as if you pick the muzzleloader to go and hunt you will not have your Remington on the mission you changed your weapons. Now this is the thing once you change your weapon you will have that weapon until you change it again. Example if I change my Remington to a Muzzleloader in the 6 mission it will stay like that until I change it so it will be a Muzzleloader in missions to follow if I don't change it. I hope this helped you! Live Laugh Love=Good Times
Jan 03, 2010 | Activision Cabela's Big Game Hunter for...
How do I access the unlocked weapons on Big Game Hunter 2010?
To change the weapons you bring with you on a hunt, press C while in the you are in the missions page - After you have selected an area, but before you've selected the hunt. You can then change your normal rifle, heavy rifle, and shotgun.
Dec 30, 2009 | Activision Cabela's Big Game Hunter for...
Hi , my abit pro 9 bios doesnt safe ,,want to install windows on a new empty drive but therefor i need to change boot device , i choose cd rom , then F10 to safe , but it freezes there , doesnt safe ,,,...
for your first boot cd/dvd rom, 2nd boot hdd is it serial ide or sata, then you can disable the 3rd boot device, if it freezes and does not save reboot your pc in some motherboard there is key to press for you choose which device to boot first if you find the key sometimes its f12 or f10 when press this it will promt which device to boot first then choose which of those devices you want to boot first
Oct 22, 2009 | Abit AB9 Pro Motherboard
Infinite Ammo for Both Chris and Sheva
the answer to this is yes complete the game once. and upgrade a weapon to max ie pistol or shotgun etc. when you start a new game you can use that weapon with full unlimited ammo on both characters. you unlock the game in the extras menu.
May 05, 2009 | Capcom Resident Evil 5 for Xbox 360
Need cheat code for playstation2 enter the matrix game.
The cheat "Maximum Firepower"/all weapons will freeze you games the first freeze spot is control tower 2 so the best cheats are infinite health, infinite ammo, and infinite focus.
These cheat should work with any version of the game.
Enter the hacking system in the game. Unlock the command allowing "cheats."
IMPORTANT: to open cheats type: CHEAT.EXE
before every cheat number, enter CHEAT
(you have to put the word help then type CHEAT.exe after that look for the word cheat on the side and input the cheatcode)
Infinite Ammo: 1DDF2556
Maximum Firepower (All Weapons): 0034AFFF
Focus Restored fast: FFF0020A
Unlimited Health: 7F4DF451
Enemies can not See You: FFFFFFF1
Turbo: FF00001A
Infinite Focus: 69E5D9E4
Test Level: 13D2C77F
Multi-Player Fighting: D5C55D1E
Fastest Logos: 7867F443
Taxi Driving: 312MF451
Enemies Can Not hear You: 4516DF45
Dodging Easily to Save Tons of Health
To dodge easily use your focus and do a wall run, a roll, or a kartwheel. {You can do the cartwheel only with the girl}.
THIS SAVES ALOT OF HEALTH
hope this helps : ) dont forget to give me a review!
Feb 13, 2008 | Sony PlayStation 2 (PS2) Console
Nintendo Spectrobes Origins for  Wii Logo
183 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
