Question about Dell Computers & Internet
Why do I have no sound.I'm not useing usb port speakers.When I go into sound management you can't change nothing
    Champion:
  • 219 Answers
Make sure you have the correct audio drivers installed.
Posted on Aug 07, 2010
My PC has two USB controllers. How can I access the second one?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if all are intact
you might purchase a usb 2 or 3card they almost install themselves and a very cheap on Ebay or
purchase a usb 4 or 5 port hub if you already have one
think about fixing the sound insteab of us
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
May 10, 2012 | Computers & Internet
3rd USB Port doesn't work and "no audio output device is installed" in Vista 32-bit
The USB port is damaged, or missing the driver for that port, check device manager.
Mar 15, 2012 | Computers & Internet
I have installed fresh and latest copy of windows 7 ultimate. Also i had installed the necessary drivers additionally. But still i cant use the usb ports and sound in my Intel DG41TY motherboard????
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 18, 2011 | Intel DG41TY Motherboard
My dell computer will not recognize the logitech speakers. I think it is something to do with the usb plug in versus a normal "jack" type plug in. I am using Vista as my OS>
Ok firstly make sure that the the speakers are connected to the green port at the back of the system tower. connect the usb cable to the usb port.
check with a headphone if there is sound . If sound is present then connect the speakers as above and then click start control panel - sounds - on this screen see if the speaker icon has a green check mark beside it , if not then click on the speakers and click use default device option present at the bottom of the screen. This should fix it.
In cases where the screen is greyed out .
strt - rgt click on computer - manage - device manager - audio device - chcek if ter is a yellow ! or red X beside it al;so check if you see other devices on screen
You could reinstall the audio drivers from the dell website support.dell.com for a DELL desktop . Reinstalling audio drivers should fix it.
try using the speaker on other system .
Hope its informative :)
Mar 31, 2010 | Logitech X-120 Computer Speakers
XP laptop no longer recognizes any USB speakers, and internal speakers dont work. USB speakers do not appear in the audio controls. the only 'device' listed under Sound Playback is SoundMax Digital Audio,...
Nothing wrong with your USB ports. MagicJack has changed your audio and driver settings so it can use the sound system for phone calls. The changes exist whether the Jack device in plugged in or not.
You can confirm the problem by uninstalling MagicJack and reinstalling your sound drivers. Should fix the problem.
You'll probably need to contact the maker of the MagicJack device for a workaround. Might be something specific to your laptop/operating system.
Nov 13, 2009 | Toshiba Satellite M45-S2653 Notebook
USB ports do not work. No sound from Speakers
Hi I am Vortash ... .. if you have your audio drivers re-install them after you Check the sound settings in advanced and make sure the speakers are not disabled .. As for the usb ports check in device manager that the usb is installed and enabled and that your drivers are working if not update if it asks search web say yes if your on the web where you are and get the latest ones ... hope this helps Vortash
May 02, 2009 | Dell Inspiron 1100 Notebook
We installed a pair of Durabrand 2.0 CH USB-powered speakers on our Compaq Presario computer, but can't get any sound. We've plugged the green plug into the sound card (green port) and the USB plug into a...
Is your Sound card running fine? Check it in device manager. The Green port is generally the correct one to use. Check all the voumes are on max and its all plugged ub rught.
Personally i reccomend you try live chat for this kind of issue. THeres to many questions to ask
Sep 08, 2008 | Computers & Internet
Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
Jul 01, 2008 | Dell Inspiron 6000 Notebook
Durabrand uc-280 don't work!
go to device manager locate the speakers, right click and update drivers, if that fails search google for that sound card driver.
Nov 12, 2007 | Audio Players & Recorders
Computers & Internet Logo
14 people viewed this question
Alun Cox
