Question about Denon AVR-1804 Receiver
I have a Denon AVR-1804. Working fine for years, now when I turn it on it shurts off after a few seconds and the on/standby mode light is flashing. It won't stay on regardless of what I've tried. Thanks for any help!
Foxyjay
  • 13 Answers
SOURCE: Denon AVR-3805
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
Foxyjay
  • 13 Answers
SOURCE: Denon AVR-1508
Hope thats of use!
SOURCE: Denon AVR 1804 Switch on and
try to reset it
To re-set the 2802, just do as follows:
1. Switch off at unit's main power switch.
2. Hold A & B buttons and turn power back on.
3. Check entire display is flashing at approx. 1 second intervals, release the 2 buttons, microprocessor is now initialized.
Hope this helps.
Posted on Sep 03, 2008
SOURCE: Denon avr-1804 its turns back after 5 sec
Disconnect all speaker wires on back and then turn on. If it happens again, it's most likely a power supply problem. If it doesn't happen again, it was probably crossed speaker wires.
Posted on Dec 28, 2009
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
I have a old denon avr-1804. try to switch on power but can not. just appear a main power red light flashed rapidlly. please tell me why?
Greetings
the red flashing LED is that the Device is in protection mode.
the internal power supply . +15 volts and -15 volts are defected you need to be replace it ... Regulators 7915 and 7815 .... these you should change , might also need to check capacitors .
these are common defects for Denon . AVR units.
Good Luck
Hope this helps
May 26, 2016 | Denon Audio Players & Recorders
Hello,pls my Denon receiver AVR-1804 is on standby and I don't know what to do to .Pls l need help to fix this fault,thnx.
Dear
The receiver is in protection mode, which means you have a problem in the power supply unit ... needs servicing.
Kind regards
Apr 10, 2015 | Denon Audio Players & Recorders
Denon AVR-3200 wont go into standby mode
Not sure what you mean by standby mode. The power button on most of the audio remotes I deal with merely turns the equipment on and off.
Nov 24, 2013 | Denon AVR-3200 Receiver
Zone 2 on my Denon AVR 1804 only works with an analog input. Apparently it was designed that way. WHY?
Because in order to use a digital input, the unit would have to completely power on. Zone 2 is designed so that it can be used with the main power off.
Sep 27, 2013 | Denon AVR-1804 Receiver
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
My Denon AVR-1804/884 standby light stays on but the receiver wil not power up
ok my denon avr 1804 was jamming and it shut off on standby red light flashing comes on then goes back off what is wrong ?????
Feb 27, 2011 | Audio Players & Recorders
Denon AVR 1804
You need to get the manual and do some reading first. I couldn't find the AVR-1804 but the AVR-1803 is avaiable. It should be close enough to get you through connection and setup.
Register with retrevo.com and download it for free.
Feb 23, 2010 | Denon AVR-1804 Receiver
Dec 28, 2009 | Denon AVR-1804 Receiver
Aug 20, 2009 | Denon AVR-1908
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
Denon AVR-1804 Receiver Logo
559 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
