Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi projection TV WS - 55413
I have a Mitsubishi HD projection TV 3.5 yrs old. suddenly the color starts purging RED and Green. But on secondary channel (PIP) it is fine. Looks like some sync is not working. what is the solution
  • timmay322 Jun 16, 2008
    how do i fix it
    Problem Solver:
  • 7 Answers
Any flashing LED's when running service mode or convergence signal?
Posted on Jun 14, 2008
Its a mitsubishi ws-55413 projection tv. the tv stopped receiving the remote funtions.
Have the remote tested alone--all shops can do this and if it tests good suspect the remote receiver in the set (usually is dead center behind the screen in the middle above the lens.
May 19, 2012 | Mitsubishi WS-55413 55" Rear Projection...
Mitsubishi WS-55613 55 color out
the problem is on the cables , look on the back of the cable box , if it is hd box the on ly thing you need to do is put the cables base on there colors green with green , red and blue , the other 2 are for video , but if it is normal box just put the yellow color with yelow on your box to your tv and the other to are audio
Jan 27, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi Medallion 1080 WS-55413 - colors not aligned
There is no "reset" as the set has in the customer and tech menus ways to attempt to manually adjust this.
under convergence in the customer menu select advanced and follow the instructions on the screen.
If Red or Blue or Green are skewed and will not adjust it means one of the two STK-394-250 CONVERGENCE chips this set uses is bad.
Depending on where you buy them they will range in price from about 12 dollars each to nearly 35 dollars each.
Let me know what you find; this may or may not be a do it yourself repair as some real expertise is required to correctly get at and replace the chips.
SD TECH
May 11, 2010 | Mitsubishi WS-55413 55" Rear Projection...
My 55413 flashes from black screen to normal. It
Howdy,
The control buttons may be getting stuck. Try this:
1. Remove front speaker grill
2. Disconnect the two cables that are sticking out of the top of the inner cover. The TV will still work with remote. If that helps replace switches, control board not available. Part Number 432P109010 quanity 9.
Hope this helps, big IRISH.
Jan 02, 2010 | Mitsubishi WS-55413 55" Rear Projection...
Mitsubishi WS-55413 timer light flashing. tv will not power on
you have some caps that have failed in the dm module
that will have to be replaced to correct the problem
if your know how to change them and have the tools the caps can be obtained through most electroinc parts suppliers
there 1000mfd 16v we increase working voltage to 35WV
if you can change them let me know and i can give you locations on the board and the dm stands on the right side of chassis at rear
Oct 24, 2009 | Mitsubishi WS-55413 55" Rear Projection...
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-65905 DTV is green
A compatibility issue rears its ugly head. The format that was to be back then has changed slightly over the years and this is what it's come to...Sorry...accordianman
Jan 04, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
153 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
