Question about Tsurumi Pump Plumbing
I have TSURNAMI POND PUMP 50PN2 25S. It just stopped running. I have pulled it out and checked that the propeller still spins and nothing is stuck. I imagine it is the starter capacitor within the top section? What else could it be? How do I test that part? where can i get that part?
  • 161 Answers
SOURCE: Bosh dishwasher shu3322uc/22
check for leaks where the the top rack plugs into the rear. it might not be sealing. If your unit has the ability to change the top rack height check in the other position and see if it works. In my Samsung (Bosch in disguise) model The tube to the top rack plugs into one of two holes in the rear, depending which rack position I use. Something covers the hole not in use. Bosch uses two seperate pumps for washing and draining. So I don't think the pump could go partially bad. (This happens in other brands when the solenoid gets stuck between pump out and recirculate)
Posted on Jul 03, 2008
  • 9 Answers
SOURCE: PUMP RUNS BUT DOES NOT **** UP WATER
I have experienced this same problem and all I needed was to prime the pump. Unless your pump cannot pump up that high.
Posted on Jan 22, 2009
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
clyde2j2
  • 137 Answers
SOURCE: How do I prime my outside of the pond waterfall pump?
I would take the intake hose off the pump and fill it with water and with the pump running I would hokk upthe intake hose.
I also would if possible have the pump lower than the pond.
Posted on Mar 28, 2009
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
Posted on Jun 08, 2009
Pump not working
hi there.
this could be a couple of things wrong.
so go to this link and have a read up on this matter.
http://www.watergarden.org/Pump-Troubleshooting
or this one.
Simple Pond Pump Troubleshooting AllPondSolutions
Dec 15, 2017 | Garden
Little giant 566134
If the pump starts after cooling down, and then starts again, it has a thermal overload in the motor, so you should pull it out and see if for some reason the impellers are stuck.... could be an easy fix.
Jan 09, 2014 | Little Giant FP3 566134 Pond Pump, 4968...
The jacuzzi magnum force pump can it be used for a fish pond
This is a lot of pump for a fish pond. You should use the safe-guards as you would find in a pool, two drain's separated by 3 or so feet and/or a couple skimmers. You dont want the fish getting pulled into the drains/skimmers. It will also be a lot of $ to run the pump compared to a smaller 'fish pond' pump ... of course your pond may be much larger than the average garden variety.
Personally, I dont think this is a good idea for a small pond. Tell me more about your pond.
Thanks for your question @ FixYa.com
Jul 08, 2011 | Jacuzzi Magnum Force Series Pool Pump 1...
Pond pump trouble
take it apart and clean it with vinegar, then rinse with plain water. make sure to take the impeller and shaft it's on, out of the little cavity and give that a good wash too.
May 15, 2009 | Nursery Pro Inc 75gph Statuary Pump
Mar 28, 2009 | Max Flo Waterfall Pump 2900 Gph
Beckett large pond pump
if by large you mean one that likes the photo you have picture it is a lost cause as it it epoxy encased and unrepairable. If thats the case buy a pondmaster or atlantic pump. proven performers that are repairable and very good warranties
Mar 22, 2009 | RTO Beckett Large Submersible 535 GPH....
Filter
You can build your own little filter by placing is in a container, like yorgart, with lid, but before you do punch holes into it no more than 1/8 inch all around. the more holes the better. this way your pump does not **** something into the chamber that will stop the propeller. I have done this and it works like a charm. Also you can use pond pots, the ones that have many slits in them.
Magnetic Drive Pond pumps can be left in the pond even if it froze. These pumps are great for weather. Once water unfreezes, pump will start again.
Jan 04, 2009 | Sti Group Sti Infinity 160 Gph Magnetic...
Sounds like it the pump needs to be oiled...how?
sometimes debris makes it way into the propeller shaft housing making an extremely bad noise pull it apart clean it out and see if the noise stops remember always wash aquarium filters and parts with the water from the tank or pond it came out of or bacterial quality will be disrupted causing the inhabited to suffer
Sep 27, 2008 | Waterway Supreme Hi Flo Pump Dual Speed 2...
Washer not spinning and draining water
I just had a similar problem. I broke down and had a repair man come out to take a look. He pulled off the front lower cover, took off the inlet hose on the water pump, and found my two year old daughters sock stuck in the turbine of the water pump. The motor runs both the drum and the pump, therfore it would not spin, and would not let the water drain.
Everything was fine until tonight. I'm having the same problem again. I pulled everything off just like my repair man did, but no sock. I think I might wind up pulling off the whole pump to check the otlet side.
Anyone else have any suggestions?
Dec 06, 2007 | Maytag Legacy Series Top Load Washer
Plumbing Logo
102 people viewed this question
Top Tsurumi Pump Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Tsurumi Pump Plumbing Expert? Answer questions, earn points and help others
