Question about Coleman Powermate Premium Plus 6250W Portable Generator
I'm trying to separate the generator from the motor (5 hp Briggs). I'm not having any luck. I would appreciate any help
    President:
  • Coleman Master
  • 1,388 Answers
I am assuming that you have removed the end bell with field winding and the only obstacle is the rotor on the crank of the engine.  I am also assuming that you were able to remove the long bolt thru rotor into crank. Now you will need to apply penetrating oil to the shaft of the engine to loosen the rust on the taper. It may take several applications. Place a piece of hardwood against metal  to protect the rotor and  firmly rap with hammer on both sides. You may need to use pry bar against engine and rotor as you hammer hardwood.  Repeat as necessary, some rotors will be very stuck due to rust. Good luck.
Posted on Aug 09, 2010
Testimonial: "Thank you, you were right just rusty on the tapered shaft I was thinking it was keyed."
Where can I get an armature for an Ag-Tronic generator, 54 Series, 5 K watt, powered by an 11 H.P. Briggs and Stratton engine and purchased in Feb. 1986 from Northern Hydraulics?
if YOU HAVE OLD ARMITURE YOU COULD GET REPAIRED OR REWOUND BY MOTOR REPAIR SHOP PRONTO ELECTRIC DOES THIS THEY ARE IN CHICAGO IL. ON NORTH SIDE
Feb 01, 2017 | Briggs Electrical Supplies
How do I remove the horizontal shaft
the motor you are working on has a split block and you have to take the motor off and remove the bolts holding the two halves of the block apart. this motor doesn't have a separate removable head. it is cast as two pieces and in my opinion makes more work for some repairs. hope this helps
Oct 13, 2015 | Briggs AND Stratton Intek Briggs &...
Have a problem with a 5 horse Briggs only can make it turn half ways then locks up
Take the spark plugs out and try again. There are several reaons this could happen. Then remove starter motor and try again make sure starter motor is free to run
Internal engine damage
Damaged starter motor
Excessive carbon in the cylinder heads (common)
Nov 07, 2013 | Briggs 3500W Port Generator
Need a replacement on-off switch for a DeVilbiss GB5000-2 generator
My switch broke as well. Instead of trying to find one, I removed it, and mounted a heavy duty toggle switch on the front of the shroud, just below the original location. Connect the original wire to one side of the switch, and a wire connected to a good ground to the other side. Btw, the off position on the toggle switch is run, and the on is now off. This repair has served me for years.
Jul 20, 2012 | Briggs & Stratton Briggs and Stratton...
Can I change a 10hp generator motor with an automatic throttle to a manual throttle?
Yes, you will be able to control the throttle. Look for a lever that pulls on the governor spring. On some generators, the governor spring attaches to an arm with adjustment screw and locknut or metal tab that bends into position. All that you need do is to pull on the governor spring to increase rpm. The governor spring pulls on the governor arm that is attached to the fly weight governor inside the engine. The fly weight is turned by the cam gear in most cases and the force that it produces is constantly trying to close the throttle. The governor spring provides the counter force to open the throttle. Without the governor, the engine can over rev. Good luck with your project.
Nov 18, 2011 | Briggs & Stratton Electrical Supplies
Put new battery on 14 hp v-twin Briggs, started and ran for a while. Shut motor off then came back and tried to start, acts like the battery is dead. Where is the generator/altenator located on these?
The generator is under the flywheel with or part of the ignition coil.
Check all the battery wiring and grounds. A bad or weak connection will act the same way.
May 22, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have an old 2500 watt 5 hp Briggs powered AC generator. It starts ok but runs rough, it seems to be running very rich. The carb is a non-float type with a diaphragm pump and only one adjustment screw,...
The five hp briggs with diaphragm pump suffered from warpage of the fuel pump cover and /or carb body due to heat from the muffler. Try this first. Remove the diaphragm cover and lightly sand it with fine sandpaper (300 grit). Place the sandpaper on a flat surface (I use a thick piece of glass) and sand in a circular motion for just a couple of turns and check to see of it was in fact warped. If it is in good shape it could be the body of the carb. I am assuming that the valves are seating ok. Good Luck with your repair.
Mar 09, 2009 | Briggs & Stratton Electrical Supplies
Coleman Powermate Premium Plus 6250W Portable Generator Logo
349 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
