Question about Cobra Digital HDVC5100 Camcorder
My camcorder wil not read my SD card. I tried cleaning it, and even tried another SD card that works on another camera with no avail.
Card reading error
Have you tried a different SD card, or a newer SD card? If the card isn't the issue you may have damaged/dirty pins in the camera memory slot. If so, there are "cleaning" cards available that MIGHT work but otherwise, it will need to go in for repair.
Apr 12, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
Camera fails to acknowledge memory card
Try cleaning SD card connectors with clean rag, and blow some dust out of a SD card connecting place, if it doesnt work try checking that SD card on some other camera, if it works take your camera to service, if SD card doesnt work on othar camera than SD card is broken.
Feb 16, 2013 | Kodak EasyShare One Digital Camera
Need help working my camcorder/camera
In order to record, the camera needs to have a memory card installed. This particular camera needs an SD format card. If the camera does not have a card installed, the card is not properly formatted, or the card is full, you will not be able to record. Also, these cards have a write protect lock tab. Make sure that the tab is not in the lock position. The card should be formatted FAT32. If you can read the card on your computer, make sure it is not full and that the card is formatted FAT32. If you have another camcorder or camera that uses SD cards, you might want to try formatting the card, just to be sure.
Jul 16, 2012 | Mitsuba DV777 Camcorder
I put in a sd memory card from my laptob but, it says no card when I tried to record.
you need to make sure that the SD card is compatible with the camcorder. Some camcorders can only read SD cards, and not SDHC cards.
Hope this helps!
Tom
Jul 22, 2011 | Jazz DV151 Camcorder
Wont read sd card
Make sure you are using a standard SD card. Most SD cards larger than 2GB are only available in the SDHC format. (Designed for Hi Def video). I did some research on your model and concluded that your camera only supports standard SD.
May 25, 2011 | Jazz DV-171 Camcorder
New Jazz DV150. Installed new batteries (tested) and SD card (tried switch in both locations). Powers on, says "Read card....", "Goodbye", powers off.
HI, I just got off the phone with a very nice man in NJ at Digitac. He walked me through a few fixes: Try a different SD card, clear SD card, put SD card in and then start camera, start camera and then put SD card in. None worked, so he said something is wrong with the camera computer and I will have to send the camera in for warranty work.
Feb 28, 2011 | Jazz DV150 Camcorder
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
Jan 04, 2010 | Jazz DV152 Camcorder
I have a kodak and it wil not let my upload my
If the camera finds it hard to read the SD card:
Memory card support for M863 is SD/MMC up to 8 Gigabyte.
If the camera is not transferring to the computer:
Here are some possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
Dec 09, 2009 | Kodak EasyShare M863 Digital Camera
Moultrie DGW-100 won't read sd card
check small switch on side of SD card; should be pushed toward contacts.Using the USB cable provided with cam, PC SHOULD RECOGNIZE DEVICE...might have to go thru windows explorer to find it, then use windows media player, or other, to open.
You are running 98 or later, right?
Apr 11, 2009 | Moultrie MFH-DGS-100 Digital Camera
Cobra Digital HDVC5100 Camcorder Logo
Top Cobra Digital Video Cameras Experts
Marvin
Marvin
Are you a Cobra Digital Video Camera Expert? Answer questions, earn points and help others
