Question about Fisher and Paykel GWL11 Top Load Washer
I have a GWL11 Fisher&Paykel top loader washing machine. Placing the washer in the wash cycle, water will begin to filling up but will not agitate or spin. This goes on for about a minute, then the #1 and #7 lights light up and the machine beeps. I can move the drum by hand - it doesn't feel bound up. Any answers.
  • 343 Answers
The fault code 130 is for Rotary Position Sensor fault. RPS is an electronic component which is neccessary for the motor to turn. It may have failed because of water leaking through the shaft seal. In this case water will have spun out onto the insides of the cabinet. This situation is probably a message to replace the machine.
If the inside of the cabinet is clean and the RPS is the only problem you would be well advised to call a serviceman. The RPS is a little tricky to get in properly and a serviceman will warranty his work.
It is not a big job for an experience tech. Get quotes.
Good luck.....Nomess
Posted on Aug 07, 2010
  • Fisher and P... Master
  • 713 Answers
Hi Mark just read your posting.Now the lights that have lit up are in a row of 8 lights and starting from the left to right the 1st and 7th lights are lit when it is beeping.Is this correct?If the information is correct then the fault you have is called SINGLE ROTOR POSITION SENSOR ERROR.The rotor sensor is located underneath your machine attached to your motor.The other 2 reasons why this fault appears is the wiring to the rotor sensor is faulty or the control module is faulty.Unfortunately to test the rotor sensor you need a device called a RPS TESTER.Also to test the wiring to the rotor sensor you will need an electrical test meter to test for conductivity of the wires.If you have or can borrow an electrical test meter I can help you test the wiring but I am sorry I cant help you test the rotor sensor without an RPS tester.Please reply to let me know how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
My Fisher & Paykel GWL11 top load wahser will only wash in cold after the first cycle. It
the problem other then the thermosat and solenoid valves is probably the main board. to check you need to replace the board with known good second hand board . buy an old machine for parts
Nov 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
Oct 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
430 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
