Question about Creative Labs ZEN V Plus MP3 Player
My Zen Freaking Froze Up!!!
My zen is FREAKING frozen.
here's what happens:
  1. I press the reset button
  2. It turns on
  3. Then it freezes after it says "rebuilding library"
  4. Now it's stuck on one of my songs and paused itself
  5. It doesnt respond to any buttons so far as I know
HELP ME!!!!! ALL TECH GENIUSES APPRECIATED!!!!!
Hello, man, i found the solution, i promes it will help you, visit this page http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=168928#M168928
in the last part, do everything it says BUT JUST CLEAN UP AND REBOOT DONT Format (All) AND Reload OS/ Firmware
Posted on May 03, 2008
    Problem Solver:
  • 5 Answers
Reset button to left - use a paperclip. If its a 4gB it might be faulty.
Posted on May 01, 2008
My creative Zen is frozen
My creative zen froze as well but if u check the bottom of ur zen there is a reset button that just turns it off and on again sorry if it doesn't work ur welcome if it does!!!
Dec 27, 2009 | Creative Labs Zen Digital Media Player
Freezes on the 'Rebuilding...' screen.
The same thing happened too me about six months ago after about a year and a half of using my zen with min. problems. It would freeze on 'Rebuilding..' and then there was an endless cycle of reset but eventually it would Rebuild completely and all my music and information was fine. It seemed to be playing fine but if it froze I had to start the reset game all over again. Then the real problems started. There are a few load screens before you make it to the Rebuild and it started to freeze on that instead after awhile. I was actually revealed when I froze on 'rebuilding..' and made it that far.
If you can get it into recover mode and reboot it seems to have less problems freezing but that doesn't even work for me anymore. Then occasionally when it freezes it starts to vibrate terribly and make a horrible sound. Then it stops and flashes hard disk problems.
This all happened slowly too me. It really wasn't worth the time I put into it trying to fix it. My advice is to work on getting a new MP3 player. If you can get it past the 'rebuilding..' your going to have to play the reset game every time it freeze and it will probably freeze more often.
Aug 21, 2009 | Creative Labs ZEN Vision:M Digital Media...
My creative zen 4gb will freeze when playing any media
It is possible a virus has infected your device. If there is no virus in it, then it require re-programming. Visit http://www.s1mp3.org and find the appropriate firmware and tool. Try to reprogram it.
Jul 06, 2009 | Creative Labs ZEN Vision:M Digital Media...
My zen has frozen and it is still on.
Try resetting it with the reset button on the side of the player. You need to use a pin to push it. If it resets successfully use the players utility to reset and check it.
Cheers
Dec 28, 2008 | Creative Labs Zen V MP3 Player
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Help frozen up zen vplus 4gb
I had the same repeating problem with my Zen V Plus 2GB. There is a tiny hole on the left side of the player, underneath the on/off switch. Stick a paperclip in there and press gently to reset your player. I lived for 6 months letting the battery wear itself out before I discovered this reset hole. I finally found the offending piece of music and deleted it from the player. I haven't had any problems with my Zen freezing since deleting that song. Pay attention to whether it always freezes on the same media, that might be the source of your problem.
Hope this helps!
Jun 27, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
I Recently bought a Zen, and it works great. The only problem I found was that it freezes itself from time to time, and the best solution to this problem is on the bottom of your Zen, there is a very small Reset hole. With a needle or a toothpick, gently stick it in, and push lightly. This will allow the Zen to unfreeze, and return back into it's regular mode. All your files will be saved, and kept on to the Zen, so you don't need to worry about losing any of your files.
Any additional help, I'll be glad to answer!
-bananaboy101
Dec 04, 2007 | Creative Labs Zen V MP3 Player
It's permanently frozen
Sounds like you have a bad hard drive and will need to get it replaced. You should take it to a technician, or if you feel confident enough, buy another hard drive and install it yourself.
Aug 30, 2007 | Creative Labs ZEN Vision:M Digital Media...
Zen sleek frozen after trying to delete songs
Why does technology make you work for what you already paid good money for? Have you tried going into Recovery Mode? You do this by holding down the Play/Pause button while triggering the Reset button. Once there, you have four options. Try selecting Disk Cleanup and then Reboot. You might need to re-Sync a few things but it's worth a shot. Good luck.
Dec 16, 2006 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
133 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
