Question about Microwave Ovens
SEACO XELSIS water circuit priming says restart to solve problem we turned it off,out of electric and then restarted no cgange, same message
2 Suggested Answers
SOURCE: my new gaggia platinum vision
We had the same problem on our machine, and it was fixed by backing the strength setting (the physical dial on the front of the machine) off from the "maximum" setting a small amount. Somehow this was creating too much back pressure, and the useless "will not prime" message appeared.
Posted on Feb 17, 2011
My Hotpoint microwave control panel will go off when it,s not in use. Sometimes tapping it will restart it , sometimes it restarts on its own
It may be a bad connection on the fuse holder, an intermittent fuse, a bad connection on one of the thermostats or elsewhere, or a bad connection on the control circuit board.
If you want to contact me privately with the model number, I can give you or a friend free DIY troubleshooting help and I also do microwave control circuit board repairs.
For more free DIY and other help and advice, feel free to contact me via my site.
Always include your FULL model number*, FCC ID number*, and detailed symptom information.
* from the tag in the cooking cavity or elsewhere on the oven (or send a clear photo of tag)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 22, 2017 | Hotpoint Microwave Ovens
Microwave error message F7
This is for whirlpool models.Try this procedure and see if it helps.what is your model?
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Feb 11, 2013 | Microwave Ovens
FMV156DCA turns on, cook indicator lights but not cooking, timer counts down fine too
Hello epinvegas - Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, then it sounds like the microwave has a faulty magnetron, wiring failure or control board. Contact a professional to assist with the repairs.
Feb 07, 2013 | Frigidaire FMV156DC Microwave Oven
I have a cv615 Miele Coffee Machine. The water reservoir was not inserted properly and water leaked into the bottom of the machine (drip tray). We got the Water System Fault message, so we removed the...
just use your hair drier to dry out the remaining water.Before doing anything remember to unplug the device.Remove the tray and other such attachments and let it to dry by itself for a day or two.this should solve the problem.never plug in the device till then.
regards.
plz. rate this
Jul 04, 2011 | Microwave Ovens
My new gaggia platinum vision will not prime. it says "prime water circuit" and makes several loud clicking sounds and then says "restart to solve the problem", but this doesnt solve...
Dec 29, 2010 | Microwave Ovens
How to enter service menu xelsis
At once when the Xelsis starts and the start screen shows up push zwice all four buttons around the display ... just follow the "Z" pattern. If you type the Z one time only a screen with the software status etc. shows up-
Oct 27, 2010 | Microwave Ovens
Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Jun 24, 2009 | Samsung Microwave Ovens
After pressing the TIME button, the number pad does not react.
A hard reset, that is, removing the unit from the electric source and restarting it after a few seconds, solved the problem.
Apr 05, 2009 | LG LMV1630 Convection/Microwave Oven
Microwave Ovens Logo
95 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
