Question about Fitness Quest Ab Lounge Ultra 1ea
I need a new Locking Arm Knob - Fitness Quest Ab Lounge Ultra 1ea
Move my OSIM uComfort chair
  1. Locate arm brackets underneath the seat pan. Unscrew the plastic tri knob until it is loose
  2. With Allen key screw the locking bolt from the threading hole until it disengages.
  3. With a Philip screw driver or a screw gun unscrew the four (4) bolts on attaching the mechanism to the seat pan.
  4. With a Philips screw driver or a screw gun unscrew the four bolts (4) on attaching the two (2) arm width plates to the seat pan.
  5. The arm pad can be removed from the arm bracket by screwing the two (2) bolts under the arm pad. This can be performed with a Philips screw driver.
Dec 01, 2017 | The Health & Beauty
Remove rear wiper arm 1998 v70
http://www.volvo-forums.com/t36992-rear-wiper-arm-v70.htm
May 10, 2014 | 1998 Volvo V70
How to replace the timer on a Kenmore 90 series washing machine?
The timer on a washing Kenmore washing machine is the brains of the unit. The timer controls how long the clothes are to be washed, rinsed, spun and dried. The timer is located behind the timer knob in the main control panel. If the timer fails, it can be replaced with just a few hand tools.
1 Unplug the washing machine's cord from the electrical outlet.
2 Remove the two screws securing the main-panel end caps with a Phillips-head screwdriver. Lift the main panel up and rotate it backward so the inside of the panel is exposed. If your model does not have end caps, slide a putty knife between the main panel and the washing machine's top, then pry up to free the panel from its retaining clips.
3 Turn the knob by hand from one side while looking at the back of the timer from the other side. You should see the timer knob's shaft turning. Grasp the black plastic locking tab in the center of the timer knob's shaft with a pair of needle-nose pliers and pull it out. You should feel a click.
4 Pull the timer knob off of its shaft. You may need to hold the locking tab with the pliers as you do this. Remove the trim plate from under the knob.
5 Unplug the wiring connector from the back of the timer. Remove the screws securing the timer to the main panel with a nut driver and remove the timer.
6 Install the new timer into the panel and secure it with the screws, using a nut driver. Install the timer's trim plate and wire connector.
7 Install the knob onto the timer's shaft. Make sure the locking tab is still pulled out before installing the knob. Once the knob is pushed onto the shaft, hold the knob with one hand while pushing the locking tab in from the other side. You should feel it click into position.
8 Reinstall the main panel and end caps, if applicable. Plug in the electrical cord and run the washer on various wash and rinse cycles to test that the timer is working.
Things You Will Need
  • Phillips-head screwdriver
  • Putty knife
  • Nut driver
  • Needle-nose pliers
  • Timer
Warning
  • Pulling or installing the timer knob without first pulling the locking tab can break the tab, the shaft or the knob.
Apr 24, 2014 | Kenmore 15944 Top Load Washer
Have a safewell electronic system safe ex2007126498 want to open it lost key and forgot the password
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the codeicon1.png as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Apr 22, 2014 | Computers & Internet
Plastic round knob on the arm you push down to start toasting, broke off. I need a new one.
Check on eBay for "Knob for Viking Toaster VT201 or VT401". This knob is available.
Aug 18, 2013 | Viking Professional (2-Slot) 2-Slice...
Here?s my problem : My scope model is LX200R 14?. I?ve pulled the focuser shaft out of the focuser arm pin. I?ve turned the locking lock knob several turns before putting back the focuser shaft. I...
Steward, this is Joe Lalumia-- I have seen your post on various forums. The 14 inch is different from the other smaller LX200 scopes.
Probably Dr. Clay, and or Andrew on the Yahoo Group LX200 forum will know the answer because they service these scopes.
Post a message there (register for free) and one of them will answer you about that very nice scope.
Clear Skies!
Joe
Dec 14, 2010 | Meade LX200R 14 in. Telescope
WE NEED A NEW BAS PLATE ANGLE/TILT LOCKING KNOB.
Here is a home page for the vanguard company. Try contacting customer support to find those parts. Good luck...hope this helps.
http://www.vanguardworld.com/gfa/index.php
Jul 11, 2009 | Nikon 847 Tripod
Needing to take off old timer knob and replace with new one
We found this on another web site:
This was super easy. If you can screw and unscrew a nut from a bolt, its that easy.
The Knob assembaly comes as a whole. So once you remove the old knob (unscrew to the Left).
Then replace the new knob assy (screw to the Right) till its a snug fit. As you will see this knob is designed to be a clockwise rotation only - normal operation - sort of a self tightening screw.
May 18, 2009 | Frigidaire Washing Machine Timer Knob -...
MAYTAG ATLANTIS DRYER TIMER SWITCH
the key is to dismantle the font ofthe knob assy( the small plastic center of knob pulls out) it also acts as a locking ring /clip to hold unto the new timer shaft
Mar 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Diverter knob & flap & gasket broke
You will have to pull the top cover off, it fits underneath unto the knob. When you see the bottom, you should be able to tell. The arm of the diverter goes thru the hole and then hooks onto the bottom of the knob.
Jul 21, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Fitness Quest Ab Lounge Ultra 1ea Logo
70 people viewed this question
Top Fitness Quest Sport & Outdoor - Others Experts
Joseph Mueller
Joseph Mueller
Dave Callender
Dave Callender
Rigger
Are you a Fitness Quest Sport and Outdoor - Other Expert? Answer questions, earn points and help others
