My mother drivers DVD is corrupted.My mother model is P5KPL-AM/PS(asus)& intel G31 chipset.How i get my mother drivers.
Solaris.arc : use this link
http://in.asus.com/product.aspx?P_ID=y014Wy067iZxxPeP
,select your operating system and download your driver
Posted on Sep 16, 2010
Intel g31 motherboard drivers
go to asus web site then to download support then type in your board then oper.system you are using then all the drivers you need then install them one by one ok.
Nov 29, 2013 | ASUSTeK COMPUTER Asus P5kpl-vm/v-p5g31/dp...
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
I would to know if asus mother p5kpl am se iscompatible with window 7 ultimate 64 bits
yes it is. =) as long as your processor is compatible with windows 7 ultimate. this is the specs of your motherbard and I think it is pretty cool:
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® Quad-core CPU Ready
- G31+ICH7
- FSB 1333/1066/800MHz
- Dual-channel DDR2 800/667
- 4x SATA 3Gb/s
- Gb LAN
- 6-channel HD Audio
please rate how this helped you.
May 26, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
I have ASUS intel G31 chipset (P5KPL-AM/PS) motherboard.Now I am not getting any display although RAM is working condition.will you help me?
this mainboard is intened for use with XP or Vista only OS and Intel Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron Processors
Compatible with Intel® 05B/05A/06 processors ONLY
go to this site to download video drivers
http://driverwhiz.com/drivers-en?brand=Intel%20Graphics&logo=Intel&subid=1002-ca-en-90000000421&gclid=CJWIgquX1KQCFcu7KgodfGqqJw
if the computer powers on w/o video , it could be heat issue with the CPU, --turn off the computer, remove battery and rear case - remove the heatsink fan and apply new thermal paste on the CPU- then put heatsink fan back , battery -- and turn on computer --if the issue persists, its bad onboard video card
Oct 15, 2010 | ASUS Maximus II Formula Motherboard
Asus P5KPL-AM IN Motherboarddrivers
Hi. Try this website then follow the steps on the buttom: http://support.asus.com/download/download.aspx
1. Choose Motherboard on Product
2. Choose Socket775 on Series
3. Choose P5KPL-AM for Model
4. Choose what Operating System is installed on your computer
Jun 11, 2010 | ASUS P5KPLAM SE Motherboard and Intel Core...
Drivers Pack For Windows Vista 7 is required
I will give you a alternate and easy way for your problem.Just download this software named driver magician and install it.It will search for the drivers for all your hardwares and components that doesnt have proper drivers and will download it.It will make your problem easy
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
May 17, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
