Question about Maytag Washing Machines
Machine making squealing sound in wash and spin cycles like a bearing is loose or something. how do you fix this?
  • Maytag Master
  • 8,220 Answers
Use WD-40. No tools needed. Tip the washer on its backside and remove the beltmachine making squealing sound in wash and spin - aa79289.jpgTurn the main drive pulley to release the brake and spray some WD-40 under the brake liner. The squeak will magically disapear.
Rate it or hate it:dc9b641.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 07, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My lg tromm washing machine makes squealing sound throughout the washing cycle
Good day,
for the sound of the washing machine may be have something inside the tub like metal or any. or the bearing of the tub is totally starting to worn-out, much better to call the service technician before to late, if the bearing problem and still using your machine some part will make problem also and its cost you a lot.
Nov 02, 2013 | Washing Machines
Squealing sound during spin cycle
Hi, the squealing could be a result of a loose or slack belt or dry bearings, try replacing the belt to see if this cures the problem.
hope this helps.
Feb 13, 2011 | Kenmore 88732 Top Load Stacked Washer /...
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Makes loud squeal noise when stoping to change cycles
when in spin out cycle when first comes on makin a noise like something is in the pump i check it and the pump is clear must be maybe lower bearing assembly sounds like something is lose or broke it also stops instancely at end of cycle what could this be
Jan 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Squealing during spin cycle
My initial comment is Yes!
It could be either ... to resolve, pop the top and remove the front. Remove the drum. Inspect the belt. Inspect the wheels. Inspect the front bearing (which is the frame around the door.
I hope this helps
a
Sep 26, 2009 | Hoover Washing Machines
Washer squeals during wash & rinse cycles.
It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
May 29, 2009 | Maytag PAV2300 Top Load Washer
I'm getting a squealing noise on the spin cycle (sounds like a bad bearing). Everything else works fine
yes, your bearings will need replacing if it is on every spin cycle the machine completes
Apr 16, 2009 | Washing Machines
Washing Machines Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
