Question about Hayward 48 Sq Ft Pro Grid Vertical Grid De Pool Filter
I cannot get the filter element cluster to release from the outlet elbow on my Hayward vertical grill filter. Any suggestions?
  • 8,404 Answers
You did release the catch ... right? It should just lift out ... off the pipe and off the rod holder onthe other side ... wiggle it if necessary.
Posted on Aug 09, 2010
Why after five minutes or so of becoming hot does the grill trip my power
When you say power I am guessing you mean the ground fault switch. Struggled with that myself until recently. There are a lot of posts out there of people with this problem with a variety of smokers. Try plugging into an outlet not protected by a ground fault outlet. If the smoker works that way (mine did) I would suggest you replace the electric heating element. For $30 bucks or so this fixed my smoker. Found my part on appliancefactoryparts.com. My smoke is a Masterbuilt brand. Putting the new element in was pretty easy but a bit messy. Look for a video on YouTube for your smoker.
Good luck and happy smoking.
May 07, 2016 | Grilling
I have to run my de4820 on recirculate otherwise my pump loses the prime. when I run the filter on recirculate it runs great. any idea why it runs better when I bypass the filter?
while on recirculate, the water is not being filtered but just returning to the pool. the first thing i would suggest is doing a bump of the grids and let them recoat with media.
Jun 01, 2014 | Hayward 36 Sq Ft Pro Grid Vertical Grid De...
How to close hayward ec75 pool filter
take apart clean elements blow out lines with air and antifreeze
Oct 24, 2012 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
I have a S-244T sand filter and I am noticing that my water level is going down about 3/4
When the pump is running is water discharging from the waste pipe outlet?
If so then the selector valve that switches the pump outlet to waste, backwash, filtering etc. is faulty.
Aug 21, 2012 | Hayward SAND FILTER, PRO SERIES
How do I change the filter on the Kenmore 335?
According to the Owners Manual, here's what you need to do,
1.Turn the air cleaner OFF and unplug it from the power outlet.
2. Carefully lay the unit down on a flat surface with the Front Grille facing up.
3. Gently push in on Release Buttons on both sides of the unit, pull Front Grille out and away.
4. Remove and discard used HEPA filter.
5. Remove any plastic protective wrapping and from the new HEPA filter.
6. Set new HEPA filter into the air cleaner.
7. Install the Front Grille by engaging its tabs into the bottom slots on the unit. Then swing grille up and gently push in top to snap into place.
8.Turn the Air Cleaner upright and plug it into an outlet for
operation.
Hope this helped you. Please let me know. Thanks
May 04, 2011 | Kenmore 335 CADR Air Purifier
The main vertical tubes to the filter element screens for my Hayward DE6020 filter are damaged. Replacement elements have a support bar running vertical down the inside of the tubes, making the tubes more...
Not tearing the filter yearly will build excess de to the point of crushing the elements or an excess of alge will clog the filter and do the same. If you have an alge problem you need to shock to kill most of the alge before running the filter to clean it out.
Sep 12, 2009 | Hayward SAND FILTER, PRO SERIES
Cannot put D.E. filter grids in correct order
Yes it is very tricky...i always start with the small one because it goes where the pipe goes down. try putting the bottom bracket into the filter and starting with the small one and see what you come up with.
Mar 28, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Hayward 48 Sq Ft Pro Grid Vertical Grid De Pool Filter  Logo
82 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
