Question about Whirlpool Washing Machines
I have a Kirkland Signature (Costco) washer made by Whirlpool. The model is #SAWS800JQ2. I am experiencing the ability to complete the agitation, however, the drain cycle won't work. I had to drain the water manually after trying to make the washer "agitate" again and again, hoping the drain cycle would function properly. I also tried to manually turn the dial to the drain cycle and pull it...to no avail.
maddogsteve1
  • 18 Answers
SOURCE: My Kirkland Signature Whirlpool Washer will not agitate or spin
broken coupler. device between motor and gearcase, look under washer behind the motor for small plastic and rubber coupler. may be worn or broken. cheap part/fairly simple fix. parts house will run ou through the process or i can provide details when you are ready.
Posted on May 25, 2009
Maytag317
  • 1136 Answers
SOURCE: Have Kirkland
Hi, Just replace the dogs. Once you remove the 7/16" bolt, the agitator will seperate.
The dogs are the same part# on all models.
Please let me know if I can assist you further.
Vic
Posted on Jun 19, 2009
marka19
  • 1430 Answers
SOURCE: The agitator on my whirlpool saws800jq2 top load
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Sep 17, 2010
dcramer531
  • 1654 Answers
SOURCE: I'm preparing to replace the agitator dogs on my
.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Posted on Nov 14, 2010
richroth
  • 9472 Answers
SOURCE: I have a Kirkland Signature
Check your agitator dogs. They are probably bad here is a link to the parts.
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Agitator-dogs-item-number-AP3119063.aspx
Here is a video on how to replace them.
http://www.youtube.com/watch?v=3iWO4bgRQ40
Posted on Nov 21, 2010
Tip
How to take apart your Whirlpool made washer
This tip applies to Whirlpool brand washers which include,Whirlpool,Kenmore,KitchenAid,Estate,Roper,Inglas,Kirkland(costco) Ikea, someMaytag,Crosley,Jennair and others made by Whirlpool<br /><br />It gets sorta confusing how to take apart these brand washers,they come apart totally different than you may think. This YOUTUBE video will show you how to take them apart<utube src="Puq8jWMY9Iw&feature=player_embedded">
on Sep 05, 2011 | Washing Machines
Washer won't drain.
It is possible that your lid switch is defective. Bypass the switch and try again-Please unplug your machine while you bypass switch. If it still does not drain the I would suspect your timer.
Lid switch Part# 3949247
Timer Part# 3955651
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool Washing Machines
The agitator on my whirlpool saws800jq2 top load washer is not spinning. where is my problem? motor? clutch?
Sep 17, 2010 | Whirlpool Washing Machines
Hi,i have a kirkland signature whirlpool refrigerator, and its not keeping anything at the right temp. all food is spoiling.i have tried turning it up but that is not working. any suggestions thanx kori
If you bought it at Costco take it back...they take anything back if you are not happy. Just kidding, it could be out of freon or freezing up.
Sep 10, 2009 | Refrigerators
Have Kirkland ''Signature'' washer that's maybe 5 years old. It does not agitate. Pulled the top cap off , (and then the inner seal), looked inside to see what was going on down there and AAAAAhhhhh! Dogs...
Vic
Jun 19, 2009 | Washing Machines
My Kirkland Signature Whirlpool Washer will not agitate or spin and the motor makes a load noise (like something rattling) when the tub should be moving. but it does drain water.
May 24, 2009 | Washing Machines
Bad smell from washing machine
does it smell like nappies or electric burning?
May 07, 2009 | Washing Machines
Washing Machines Logo
174 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
