Question about Dewalt 18 Volt Compact Drill Kit
Drill runs for a little bit you shake it and it stops
  • 2,176 Answers
Could be a loose wire or the motor, I would go to Dewaltservicenet.com before removing anything. This tool might have an access cover to inspect the brushes, they are I belive a T15 torx.
Posted on Aug 09, 2010
Shaking during idle when warm.
try injector cleaner or newer fuel cleaners, try octane booster, sounds like a fuel delivery symptom but the temperature factor is a worry. I would guess injectors.
Jan 18, 2015 | Cars & Trucks
Hyundai wiper arm not working
A quick fix is to first put the wiper arm into the correct position then drill downward through the wiper arm and into the wiper pivot.Don't drill all the way through the whole assembly,just 3/4 through the whole thing.Then break off the drill in the drilled hole.The hardened steel drill will run the wiper arm on the pivot.Dab a little sealant on the drilled hole/drill bit and run the wiper with no problem next time it rains..
Mar 01, 2018 | Hyundai Motor 2003 Sonata
I have a Hitachi WH 18 DFL cordless impact driver, which I love. I was doing a little bit of heavy drilling, and now the drill bit is stuck. The sleeve extends as if to release the bit, but the bit do
My guess is that the bit twisted a little in the bit holder so the steel ball is bound. If the collar moves you could try a slide puller on the bit and see if you can impact it out with the slide puller. Or you could take the bit holder apart. There is a retaining ring that holds it all together right on top. Pull that off and a washer, spring and the collar will come off. Becarefull to watch for the steel balls on the spindle. They WILL fall out! Now hopefully the bit will come out. If not it may need to be twisted in the oposite direction that it got stuck when you were using it to break it free. Hope that helps and good luck!
Jan 19, 2012 | Dewalt 18 Volt Compact Drill Kit
Cant seem to drill into concrete with tapcon bit in 18V P205. What settings and speed do I use?
You should be able to drill at a low speed. Maybe 100-200 rpm. I assume the bit is sharp. I have run into an ocassional new bit that is bad. If it suddenly stops drilling you may have hit a rock. Crack the rock with a center punch then continue drilling.
Apr 01, 2011 | Ryobi 18v 38" One+ Cordless Drill P205 18...
How to get the drill bit out
Try some WD40 make sure you are pushing the release, pull back on the head as you shake the bit out.
Apr 01, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Jan 04, 2010 | Dewalt DC925 Cordless Drill
Jammed short shank drill bit in ring grabber drill driver
Mix a little JB weld stick anything to head of stuck bit. let harden and pull the sucker out.
May 16, 2017 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
May 04, 2009 | Drills
2004 Chevy Malibu won't start and shakes when stopped at light
The next time it starts shaking and acting up its the time to have a fuel pressure test, or maybe if you can't remember the last time the fuel filter been chg. do that and see if it dosent run any better. Could be filter getting cloged up, or maybe pump getting weak and dosent show up until its run a while and has got warm.
Mar 29, 2009 | 2004 Chevrolet Malibu
Dewalt 18 Volt Compact Drill Kit Logo
75 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
