Question about SanDisk Audio Players & Recorders
I have an Sansa Sandisk Express, and I also have a 2gig Micro SD card that I put music on, bvut when I put it in and start it up, it just stop loading and says reset data list do not remove Micro SD... any ideas on how to help me play the music on the micro sd?
Had a problem with this myself. Try holding down the select button... The box like button in the middle and the volume + button at the same time. This took is back to it's original condition and now works fine.
Good luck
Posted on Feb 20, 2009
When I put music on my Micro Sd card I can't play it.
Make sure the music is in a folder named "MUSIC".
Feb 10, 2010 | SanDisk Sansa Fuze MP3 Player
My sansa express dosnt know it has a micro sd card full of music in it. please reply to: benharris185@msn.com
Early versions of the Sansa express will not support High Density microSDHD cards whcih are usually found in Cards greater than 2GB and definetely on cards greater than 4GB.
In Flash drive mode, make sure that the microSD card can be seen on your PC as a second drive for your Player. To ensure better compatibilty, I would suggest that the microSD card be FORMATted while inserted in your Player.
I would initially only put a couple of songs on your microSD card to test that the card is compatible.
Dec 22, 2009 | SanDisk Sansa MP3 Player
My PC does not recognise the Sansa express and it is not on
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Jun 16, 2009 | SanDisk Sansa MP3 Player
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
How do i use a micro sd card with my sansa e250
It's pretty simple really. To actually get music on your micro sd card you have to put it into an adapter and connect it to your computer. Then you have to put the music on the card seperately. Then plug it into your sansa and it will recongnize the songs and play them like normal
Jan 25, 2009 | SanDisk Sansa e250 MP3 Player
Trouble with expanded memory
The Sansa Express was only designed to hold up to a 2 GB Micro SD card because that is as much expandable memory it was meant to read. Anything bigger as in your case will cause the player to go slower than normal as it tries to read the card and after a while, it will most likely freeze. If you try it with a 2 GB Micro SD card, it should work.
Dec 10, 2008 | SanDisk Sansa MP3 Player
My Sansa Express Music Player shows mulfactioned error
Insert A Micro SD Card And Start It Up
It Should Work
Shut It Down And Remove The Micro SD Card
It Should Startup Fine.
Sep 09, 2008 | SanDisk Sansa c150 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
135 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Sanath Kumar V
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
