posted by bcws on Apr 27, 2008
some months ago the insulation strip started rising from below the glass window in the door of my micro/convection oven. Haven't seen any other comments to this effect.
Then yesterday it started making loud noise and not heating. Probably two separate problems.
Best Solution
posted on Apr 27, 2008
I think you're correct, unless it was arcing while cooking.
The warping is not a problem until and unless moisture can get rapped and damage the fine metal mesh / screen inside the door panels.
The lack of heat with a loud noise is usually a shorted high voltage diode or failing magnetron. I would of course focus on getting it to work before I tackled the door trouble.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Assuming yours is a GE JEB1095 as per your posting category, there should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Rating Locked! (?) bcws has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for GE JEB1095 800 Watts Convection /
Email this problem
Email this problem
Can you Help with these Microwave Ovens problems?
GE JEB1095 800 Watts Convection / Microwave...
Unit loses power
Unit loses power
Unit loses power after a few... Answer This...
ge microwave/convection oven
The convection part of the oven... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
Find Parts
