Question about Panasonic PT-47WX53 47" Rear Projection HDTV
We recently had a problem with our PT-47WX53G 47" HDTV (3-blink indicator issue) and had all the convergence parts replaced. This morning the TV shut off and now when we attempt to turn it on again, the red indicator light only blinks once. We were having occasional wavy lines the last few weeks too. Is it the convergence issue again? I can't find any info regarding the single blink. I'm wondering if the TV repair shop should be held accountable for a partial fix from the first time.
  • 11,896 Answers
This may be a convergance issue. You could have a faulty IC chip that is causing this. However, you should still have sound. Usually when you get the red light, then the flyback or power board is faulty.
Posted on Aug 07, 2010
Pt-47wx53g tv won't click over n than the power button will blink 5 times
IC4511 has failed on the DG board replaing the DG board as a unit i the only way to fix the issue. The DG board isnt serviceable
Jun 01, 2012 | Panasonic PT-47WX53 47" Rear Projection...
How do i remove the convergence board on my panasonic hdtv projection model number PT-47WX53G and is the any risk in electocution even after beeing unpluged
You have to remove all the cables and screws first...if you not sure how its done you can goto sites like www.TvRepairKits.com that have the parts and instructions to fix this yourself. Its a common failure on projection TV sets.
Aug 07, 2011 | Panasonic PT-47WX53 47" Rear Projection...
I need a lamp for a Pt-47WX53G set with an AP825 chassis. Can someone give me the correct part number?
This is a rear projection TV set. Therefore it has three CRT's in it and not a lamp or bulb like you see in a DLP tv. If tv isn't turning on it is most likely a convergence or power supply issue.
If you think you need a CRT then the part number is on the side of the CRT at the top. These are not easy to replace and are quite dangerous to handle if you have no experience.
I would not recommend any novice to attempt a CRT replacement.
Feb 24, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Convergence problem on pt-47wx53g
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Your TV will commonly have one or more of the following symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio or Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I cannot get the blue convergence cross to line up with others.
The tv convergence board is dead.Any colors G,B,R don't alignment matches up.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT 47WX53G does not turn on
If the indicator blinks three times its the error for the convergence ICs and resistors. You can get the right repair kit for your model at the following link which contains the Two ICs the 6 feed resistors and detailed step by step instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jun 10, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Replace STK392-110 IC's ( both ) with PANASONIC part
# C5AA00000203.........DO NOT use generic IC's !
Terry.
Jul 22, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Convergence
It's a possibility that this board may be at fault or it is also possible that the convergence amplifiers are drawing too much current and shutting the unit down. This may require replacing both IC's along with a convergence touchup, or as you mentioned, it may simply be the job of swapping the Digital Convergence board PN TNP2AA120S.
Aug 26, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
65 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
