Question about LG Electronic Window Air Conditioner
I have an LG 110 volt model-LWHD1200FR this is the 2nd summer we have used it and have always kept thermostat set to 60 deg. The last couple weeks the front coils have been caked with ice, what would cause this? I use the blow drier to melt it and within 12 hours or so its caked with ice again. any ideas would be greatly appreciated. Have tried cleaning the filter,gently cleaning the coils, didnt make any difference.
    President:
  • 3,773 Answers
Clean both the cond and evap coils if they don't let the air through
that can cause icing
Check for strong air flow front and rear
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 07, 2010
Compressor will not kick on no matter what temp the thermostat is set at
This could be a couple things. 1 . A bad capisitor, 2. an bad set of contacts, 3. a bad thermostat. You will need tools and electrical knowlege to evaluate it.
Aug 07, 2011 | LG LWHD1200FR Wall/Window Air Conditioner
Hi, need head torque settings for a 2000 daewoo nubira 1.6, thanks
In four stages, first with a calibrated torque wrench, then an angular torque gauge.
1st stage 25 nm (18 ft/lb) 2nd stage 60 deg
3rd stage 60 deg
4th stage 60 deg
5th stage 10 deg
order:
10. 6. 2. 3. 7. 9. 5 .1 .4 .8
New bolts ahould be used when head, and/or gasket is replaced.
Thank you for useing FixYa and i hope this answers your question.
Jun 28, 2011 | 2000 Daewoo Nubira
Freezer has thawed twice in the last 2 weeks
Hi and welcome to FixYa, I am Kelly. This can be caused by several things but usually when it thaws on a routine basis the automatic defrost bi metal thermostat has failed. Using this model number PSS26MSRCSS and this diagram:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5219887&diagram_id=23192126#d23192126
The failed part would be item 240. It is possible however that the thermistor Item 241 could also cause this symtom.
Make sure to read the information about the Defrost thermostat using the link below. Just note that a defrost thermostat will have continuity anytime the temperature is below 60 deg F.
GE Thermistor testing can be found here:
http://www.appliance-repair-it.com/refrigerator-thermistor.html
These are the 2 most common reasons that the a refrigerator will thaw out on a regular basis. Now there can be things like a problem with the PTC relay or thermal overload on the compressor in the form of loose / hot terminals or a bad relay / overload assy. Lastly and repair of last resort the compressor can be dragging and not starting properly or the rotor occasionally locks.
I believe that if you change out the thermistor and bi-metal thermostat that your defrosting probelm will cease. We usually change them both at the same time because the control board is electronic and under nomal conditions the thermistor controls the defrost cycle. The Bi-metal thermostat is there as a back up to terminate the defrost cycle when the temp at the top of the evaporator reaches 60 Deg F and at that time cycles the compressor to start.
Having said all that... if the defrost heater Item 230 of the first link is not heating up at all; the unit will defrost / thaw to 60 deg F every defrost cycle. Most of them will have Blue and orange wires on them and you read resistance at each end of the glass tube on the terminals. No resistance = an open / failed element.
Thanks for choosing FixYa,
Kelly
Mar 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have an Audi A4 1991 2.6 V6 model, with a overheating problem since they fitted a new radiator, it goes up to 90 deg but then after about 10 km it goes over to 100 to 110 deg. Could this be a faulty...
it could be. im surprised it wasnt replaced at the same time. make sure the air is bled from the system after installation. you have to remove the drive belt to access the thermostat. when replacing make sure the small check valve on the thermostat is facing up. heres a couple pictures to aid you. hope this helpsonetufshoppe_84.gifonetufshoppe_83.gif
Jan 31, 2011 | 1996 Audi A4
Entire cooling shut down - restarted 10 hours later, shut down again 12 hours after restarting.
The defrost cycle is usually terminated by a 60 Deg bi-metal thermostat. If the defrost heating element is not heating up the unit will shut off until the internal temp reached 60 Deg F and then restart.
Defrost cycles are 10 - 12 hours apart depending on the defrost control installed so that explains the 12 hr repeat. I really think you have a bad defrost heating element. Here is why I say that...
1. The Defrost cycle is 12 hours after last defrost. (Means the defrost control /board is working)
2. The defrost cycle terminates at 60 Deg F
3. No working defrost element will cause very very long defrost cycles due to the time it takes for the compartment to warm up to 60 deg F and terminate the defrost cycle.
The element is item 33 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164987&diagram_id=28252332#d28252332
Just looking at the drawing it appears that the Defrost heater and defrost thermostat are an assembly.
You should be able to read resistance end to end on the heater assembly. If you have no resistance it is most likely open / has failed.
The defrost thermostat will read resistance anytime compartment temp is BELOW 60 deg F.
Thanks for choosing FixYa.
Kelly
Jan 19, 2011 | KitchenAid Superba Architect KSCS25INSS...
LG LRFC22750ST fridge is 3 years old and the top half has stopped cooling. The freezer seems to work ok. This happened a couple of weeks ago where I opened the door and found the refrigerator half...
During the Automatic defrosting cycle there is a 60 Deg F thermostat on the evaporator that must cycle to terminate the defrost cycle and restart the compressor. If for some reason the defrost heating element is not coming on (failed / open / wire terminal problem) The the unit will just sit not operating until it reaches 60 F in the evaporator section of the freeser compartment. I suspect that you have an Automatic defrost heating element problem. Again that can be from a broken wire / terminal or the element itself has failed. It is possible that the 60 deg F thermostat itself is sticking and not cycling when the temp of the evaporator reaches 60F. It can also be caused by the temperature control that does not complete the circuit and start the unit when the fresh food section reaches cycling temp 34 - 37 deg F.
Your particular unit uses a thermistor and what is listed as a sensor to control the defrost and cycle temp circuits.
Parts list here:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LRFC22750ST/3204/0161000/P0809090/00002?blt=06&prst=&shdMod=
Sensor is Item 903E
I am NOT telling to order anything thing. The only way to find out is to read out the components.
Kelly
This requires that the back of the freezer compartment be opened to troubleshoot and repair. Troubleshooting is done via resistance checks from the defrost control board or timer to the compressor. Usually blue wire from the control to the orange wire on the compressor then finding out which component has failed by reading resistance before and after each component.
The only way to find out is to use a meter.
Kelly
Sep 23, 2010 | LG LRFC22750ST French Door 22.4 Cu. Ft....
Will not start
circut board has a short by the sounds of the system. This board is located in a box right behind the control panel
Apr 15, 2009 | LG LWHD1200FR Wall/Window Air Conditioner
LG Electronic Window Air Conditioner Logo
154 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
