Question about Garden
S31SST fuel line connections - Garden
  • 11,896 Answers
Goes from tank to carb. Some have filters but not all of them. Some filters are in the tank itself. Just form tank to carberator. Some of them if too long do get bunched up.
Posted on Aug 07, 2010
  • elm1026 Aug 07, 2010
    There are two lines in the fuel tank. I need to know how they connect to the carb.
  • Nate Stansfield
    Nate Stansfield Aug 07, 2010
    Line on left is the purge line, line on right is main fuel line
    http://www.dixiesales.com/ipl/278/s31sst...'Snapper%20S31SST'
Oh it's snapper s31sst weed eater
I love this brand,, really eats up the weeds.
May 31, 2015 | Garden
I put brand new carb on weed eater snapper s31sst model runs wide open when should idle and close choke it idles down the way it should my cell changes the letters I type in
Check the the ldle screw play with it screwing counter clockwise or clockwise don't play with the high and lo adjusters
May 30, 2015 | Garden
Craftsman Gas Powered Blower Mode 358.794772: Fuel lines broken and need replacement. Have new parts from Sears. One fuel line goes to the carb and connects to the fuel filter inside the fuel tank The...
A special fuel filter must be on the end of the fuel lines going into the tank, the line should be long enough for the filter to move around by gravity to stay in the fuel as the tank empties.
Sep 13, 2013 | managemylife.com
Pull cord snapper s31sst weedeater
how can I replace a pull cord
Mar 15, 2012 | Garden
I have a snapper S31SST weed eater. When it starts it will run for 15 to 20 seconds and stall. I have found that if I slowly depress the primer bulb it will run longer. What could the issue be?
Hi diamondt41...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Aug 23, 2011 | Garden
Need to replace fuel lines....does the prime bulb connected to return fuel line or the supply fuel line
Hi stglass900...
Normally the big line will be the line the fuel filter is connected to inside of the tank, and is connected to the primer bulb.
The smaller of the two lines is the return line to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Aug 16, 2011 | Craftsman 25cc Gas Line Trimmer
What's the best way to adjust the carburetor gas flow on a snapper s31sst weed trimmer?
Technically the answer is to correctly adjust the L and H mixture screws on the carburetor. Here is a tutorial on how to do this.
http://www.zamacarb.com/tipspage.html
Aug 13, 2011 | Garden
How do you get the drive coupling off of a snapper
there is a small torx or star headed screw down inside the nose of the clutch behind where the drive cable goes in, you will usually need to hold the flywheel firmly in order to break to screw loose
May 24, 2010 | Garden
I have a snapper S31SST weed eater. It is 4-5
Remove spark plug and check for fire with a spark tester. (some inline models are also available and safer since the spark plug stays in place using those types)
If no spark:
Remove covers and unplug small kill-circuit wire(s) from ignition coil...Test for spark.
If you have spark the switch needs replacing.
If you have no spark the coil needs replacing.
Hope this helps.
Sep 26, 2009 | Garden
Fuel line connections coming from fuel pump on 1999 Chevy S10 4cy
Id say the fastest way to find out which line is the pressure side is to put both lines into a bucket and turn the key on for a second. the pressure line will have fuel coming out of it...other is the return line.
Mar 19, 2009 | 1999 Chevrolet S-10 Pickup
Garden Logo
193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
