Question about Philips FTR-9964 Tuner/Receiver for Plasma
Menu I have a Phillips plasma for 2 years and now whenever I turn it on, it goes to the menu instead of the channel. If I exit it using the remote, seconds later the menu will appear again, making it impossible to watch any channel.
  • 2 more comments
  • david gordon Apr 30, 2008
    the same problem turn on my tv and menu pop every 8 seconds
  • Anonymous Jun 09, 2008
    same problem
    anyone have directions on how to fix this
  • ceejaie Oct 19, 2008
    what software I need to download and how to apply it to the tv? please advise
  • Anonymous Mar 13, 2009
    TV menu stays on all the time when powered on. No idea how to resolve. Under warranty
I have the same problem =(  I will try using the software.. this work for anyone else?
Posted on Sep 02, 2008
I download new software from internet and insert to TV and it works.
Posted on May 02, 2008
Service menu codes for P42H401 plasma
(1) With Plasma turned On, Enter the I2C Service Menu: (Remember, you are doing this without seeing a picture).
  • Press "EXIT" once, just in case TV Guide is brought up for Set-Up.
  • Press "Menu" and wait a few seconds.
  • Press "Menu" ~ "Menu" ~ "8" ~ "Select" Buttons on the Remote:
  • The Service Menu is entered, even though you can not tell.
Service Menu selection you can not see
  • To navigate and adjust while in the Service Menu, use the remote control's Cursor Keys.
Dec 31, 2010 | Hitachi P42H401 42 in. Plasma HDTV
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
My tv is stuck in retail mode, how do i reset that?
Enter the OSD menu by pressing Menu on the remote or the TV. Press the down arrow to reach Installation (bottom of the list) and then press the right arrow to to enter this menu. Then navigate to Preferences (third in the list) and press the right arrow. Then navigate to Location and again use the right arrow to enter this item. Set the unit to Home instead of Shop. Press OK on the remote to save the setting. Then press Menu to exit the OSD.
If you are using the controls on the TV, use the Volume +/- buttons to navigate left or right in the menus. The Channel Up/Down buttons will let you navigate the vertical menus.
Once in the Home Location, you can adjust the color or brightness. From the Menu, choose TV settings and then Picture.
I hope this helps.
Dec 07, 2010 | Philips 50PFP5332D 50 in. Plasma...
Sound it on and can change channels, but no picture. The screen is showing the set-up mode. I have called the cable company thinking it was the box, removed the batteries from the remotes, re-booted...
try reset to defaults:
  1. Press the 'MENU' button.
  2. Press the cursor down to select SETTINGS.
  3. Press cursor right twice.
  4. Press the cursor down to select RESET AV SETTINGS.
  5. Press cursor right on START NOW. Press the 'OK' button.
  6. Press the 'MENU' button to exit the menu.
Feb 20, 2010 | Televison & Video
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
Phillips plasma tv. Settings menu pops up all the should have a software upgrade for your TV to fix the problem. This is a common problem with Philips TVs and they have made upgrade software to address the problem.
Go to the Philips web site and all the procedures for download to your TV will be there. The only thing you will need to this is a USB memory stick. Download should be FREE.
Aug 03, 2009 | Philips 42PF9630A 42 in. Plasma Television
My phillips 42 in. goes directly to the menu screen.
It's a common software problem with the Philips TVs. You'll have to download the latest software upgrade to fix the problem. Go to to find the software for your TV. You'll need a USB memory stick to do the procedure followed on the web site.
Jul 16, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Problems with getting channels locked in on our plasma tv
Yuo can change the pin # even if you don't know the old one then you can can turn off with the new one.
Press the 'MENU' button on the remote control.
Press cursor down to select SETTINGS.
Press cursor down to select MENU PREFERENCES.
Press cursor right.
Press cursor down to select CHANGE PIN.
Press cursor right once.
Enter code 0711 if you have don't know yours
Enter a new four digit PIN using number buttons. Number combinations from 0000 to 9999 are valid.
When prompted to confirm PIN, enter new PIN again.
Feb 22, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 14PT6107S/05
I found this on the net:
Try this, there are 2 versions of this set, one of these will work.
Option 2 worked for me. The thing I was failing to do was going in and out of 'standby'.
Also there is no 'all' instead 00 = 'all'
Jun 12, 2008 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Open Questions:
Televison & Video Logo
186 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
