Question about KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher
Kitchen aide dishwasher won't start. Water left in bottom after last cycle. No lights will come on along the panel. KUDI01FL
I had this and the thermal fuse needed to be replaced ($14 part).
If the lights won't come on on the controller and you are sure you have power to the dishwasher, then check the thermal fuse.
1. turn off the power to the machine
2. open the door and unscrew all the screws along the inner edge
3. gently split apart the layers of the door and access the controller; it is inside the door and just below the buttons that are supposed to light up.
4. the thermal fuse is white and clipped onto the side of the control box close to the top of the door.
5. unplug the leads going into it and check it with a multimeter - if no current goes through it then it needs to be replaced
relatively easy fix - good luck!
Posted on Oct 31, 2010
Kitchen Aid dishwasher won't start. All keypad buttons/lights appear to be functional.
The touch pads are common to go bad. It could be a bad start switch pad or bad control board.
Oct 05, 2014 | KitchenAid 24 in. KUDS01FLSS Built-In...
Kitchen aid dishwasher
The washer is filled up with water because it is at float level. So basically same water to clean again and again. You will have to remove kick panel at the bottom front for access to the pump and drain hose.
Apr 24, 2013 | Dishwashers
Kitchen aid dishwasher not running
Check your breaker or fuse panel first.
Dec 12, 2011 | Dishwashers
CHANGE COLOR OF KITCHEN AID DISHWASHER
Go to www.applianceart.com
They have many options available for changing the color of your Kitchen Aid dishwasher. They also have designs, textures and stainless steel.
Apr 10, 2011 | KitchenAid 24 in. KUDI01FL - Multiple...
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishes dont get washed soap left on door something not right
Soundl like you're not getting water going into the dishwasher. Check out the water inlet valve.
Nov 19, 2009 | Whirlpool Dishwashers
Water left in the bottom of a hobart (kit aid) dishwasher
Drain valve not opening, kinked or blocked drain hose. Remove the hose from the sink plumbing and look for debris. try running the drain hose into a bucket to eliminate a domestice plumbing issue, but hold onto it when it starts draining, or you will have a wet kitchen. Timer contacts may not be opening drain valve.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher Logo
267 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
