Question about Asko W6441 Front Load Washer
I have an Asko W6461 Quattro 1600 RPM. This is the worst washing machine I have ever owned. I have spent so much money, water, electricity rewashing clothes because it always smells musty and moldy. I have checked with my manual and there was nothing stated about this potential problem. A customer service rep kept denying there was a problem until she finally admitted it and told me that I had to clear out the drain and the bottom of the machine after every wash (ARE YOU KIDDING ME???) and to run a cleaning agent for front end loaders found at stores every once in awhile and to clean the rubber seal. I have done all this and nothing seems to work. My towels especially smell. I remove them from the machine as soon as the machine is finished and it smells. I will get a "clean" towel from the drawer to dry dishes and as soon as it gets wet, the musty, moldy smell reappears. The same with a "clean" towel that is used after a shower. I do not know what else to do aside from pushing the machine out the window and telling anyone who will listen to never purchase this machine.
Timon90
  • 126 Answers
SOURCE: Bad Musty Moldy Odor in Washer
Run a wash on the highest temperature, and add some vinegar into it. May do this more than one time. Be strict to wash on the higest temp some times in the month.
Good Luck
Posted on Jan 24, 2008
  • 351 Answers
SOURCE: Asko W6461 - will not drain
is the pump comming on look inside the pump with a tourch there may be somthing stuck behind the impeller
Posted on Apr 09, 2008
dauphine
  • 207 Answers
SOURCE: Asko W6431 Quattro front loader
Unplug the machine. Remove the filter, take a flashlight and get your head down to check if something has fallen deeper in filter and pump housing which block the pump turbine. Also, make sure to check if the outlet hose isn't clogged or jammed with something too.
Posted on Apr 24, 2008
  • 135 Answers
SOURCE: Clothes smell.
Mold, mildew and other fun things use washers as a breeding ground. Clean your machine with a generous amount of white vinegar run through a cycle. Or there is a product called Affresh you can buy at Lowes or Home Depot.
Posted on Jun 21, 2008
jumptrout51
  • 3361 Answers
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Posted on Mar 10, 2009
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
I have an ASKO W6021 Quattro 1200 RPM. It does not complete the wash cycle. If I turn the know to rinse, it does rinse and completes. I tried it without any clothes in it and it does the same thing. I also...
Check that the cold water is turned on. The washing machine uses cold water to rinse, and if the cold water is not on, unit will end without completing cycle.
Mar 14, 2011 | Asko W6021 Front Load Washer
Hello, I have an ASKO Washer model W6461 and I notcied a puddle (1/2 cup) under the front right part of the machine after running it once. How do i get the service manual for this machine so i can...
you may find the leak coming from the door seal or the soap drawer while it is filling,if you leen the machine back you will find two T20 screws under the front.you can get the book from asko.com.au
Jun 15, 2010 | Asko W6461 Front Load Washer
Asko washing machine won't drain.
Further on to this F3 problem I had the issue on model W6461. There is a short cut to the fix, instead of taking off the grey pipe from the drain pump (the hose clips are pre crimped in the factory so as stated above are difficult to remove) try this.
Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear through back the coin trap.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water.
Just ran the machine now and fault cleared.
Good luck
Jurgo
Apr 30, 2010 | Asko W660
Need new stabilizer clip/bolts for ASKO washer model W6461
Don't need those bolts except for shipping the washer. They were supposed to have been removed a long time ago.
Sep 18, 2009 | Asko W6461 Front Load Washer
Apr 06, 2008 | Asko W6461 Front Load Washer
Asko 12505
It's probably the heater, or the thermostat. You must have a serviceman to fix that:)
Feb 03, 2008 | Asko W6461 Front Load Washer
Asko front load washing machine
ring the asko service number on the inside of your door,1300 002756 ask for spare parts
Dec 15, 2007 | Asko W6461 Front Load Washer
Asko W6441 Front Load Washer Logo
687 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
