Question about Vacuums
Looking for replacement power cord charger for bisell spot lifter 1715. Part Number 203-2506
  • 1 more comment
  • ksksb2 Dec 17, 2008
    I need a new charger/charger cord for my Bissell Spot Lifter 1715 Series.
  • Anonymous Jan 14, 2009
    i'm looking for the same part
  • Debi Carter Sep 26, 2013
    This charger cord is no longer available anywhere, it is very hard to find, good luck if you can!
Go to bissell.com and put in the model 1715 look at the owners manual and in that it gives you a part number. # 203-2506 for the charger you can order one from bissell. call 1-800-237-7691
Posted on May 27, 2009
Where do i find the serial number for the Bisell Power groom Helix
It should be on a tag on the back or the bottom of the vacuum
Apr 02, 2015 | Vacuums
Where can I purchase a replacement hose for my
currys.partmaster.co.uk stock bisell spare parts
Jul 16, 2009 | Vacuums
Charger for a Bissell Spot Jifter
I had the identical problem -- a box full of combined chargers! Bissell tech support (1-800-237-7691) informed me Feb. 23, '09 that the 1715 charger/cord model number 203-2506 is 4 amps.
Feb 01, 2009 | Vacuums
Bissell Spot Lifter
ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
Feb 29, 2008 | Bissell 1715-G Spotlifter Bagless Handheld...
Model Bissell Carpet Cleaner
I just needed the same info and found the model number - you have to turn the whole unit over. It's underneath the the vacuum unit, near the brush. Hope this helps.
Dec 22, 2007 | Bissell 8910 ProHeat Clear View Upright...
Bissell 1715-g spotlifter
Go to Bissell.com., put in your model number and if available, you can download it from there.
Nov 09, 2007 | Bissell 1715-G Spotlifter Bagless Handheld...
Vacuums Logo
750 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
