I have a potterton proforma28 boiler can anyone advise how to get hot water back as it seems to have gone off
You need a diaphragm repair kit part number 5111137 the round rubber diaphragm will have split and wont be pushing the pin out onto the microswitch to ignite the boiler in hot water mode we have the kit you require in our e bay shop UNIVERSALHEATINGSPARESUK
Posted on Sep 02, 2010
  • Heating & Co... Master
  • 3,328 Answers
If you go to the baxi potterton wed site you can down load a manual with fault finding on your boiler as this could be a number of things
Posted on Aug 08, 2010
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
I have a Potterton Combi Puma 80e When I use the shower the pressure seems to drop and shower goes cold! except when the central heating is on shower works fine
Does the red status led in the centre of the control board come on when hot water is drawn? You need to remove ONLY the front decorative cover to see the control board, two fixing screws at the base of it. If not the boiler won't fire when the CH is off.
The trigger for this is a pressure switch, replacement of which is beyond DIY scope.
FYV
Feb 11, 2013 | Water Heaters
Need Manual
Try the baxi potterton wedsite you can down load manuals there or they have at tech line
Nov 24, 2012 | Heating & Cooling
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
Potterton Suprema status light.
Are you getting Hot water and Heating?
The reason i ask is because I don't think you have a problem.
On this boiler it has a 'pump over run' thermostat incorporated into it, this ensures heat escapes from the boiler by using the pump to cool it down.
If you are getting hot water and heating, leave it well alone, if you reset the boiler this can have adverse effects on the boiler and evenually cause malfunction.
However, if you find that you are not getting Hot Water or Heating, then the most common fault on this boiler is the PCB (Printed Circuit Board) it is the 'brain' of the boiler and the most common fault on this make. (£160 + vat)
I hope this helps,
Steve
Jul 06, 2009 | Broan-NuTone 658 Central Heating System...
Potterton Profile 60e doesn't start first time
could be fan speed or air pressure switch-is case seal sealing properly also check grommets under boiler for blowing.
YOU CAN ONLY WORK ON BOILER IF YOU ARE GAS SAFE REGISTERED.
Apr 04, 2009 | Water Heaters
Repressurise Potterton Performa 24 boiler
hope this is helpful. On my potterton 24 combi boiler it is the valve that sits the lowest, with a slight indent in the black tap. if you turn this for a short period you will hear a hiss and the pressure will quickly build to the desired pressure, when you can them turn the tap back off.
Jan 07, 2009 | Heating & Cooling
Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Nov 02, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
232 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
