Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
Samsung lnt4071fx/xxa diplaying vertical and horizontal snow lines
IrishDruid
  • 2712 Answers
SOURCE: 42" samsung ed plasma tv
There are several things that can cause it. You are best to have an expert technician come in and take some test on it in order to determine if it is from vertical blanking failure or something else. It is not easy to fix this yourself, if you have no experience, because there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
tvservice306
  • 458 Answers
SOURCE: black horizontal line, red parallel vertical lines
REPLACED LCD PANEL
Manufacturer Sharp Part Number RF-R1LK420D3LF2 Description 42" WIDE LCD PNL -
Posted on Sep 28, 2009
nikeananth
  • 267 Answers
SOURCE: horizontal lines and colored snow
HI,
There are three likely causes for horizontal lines on your plasma TV.
1) A bad incoming signal. Do you see the lines on every channel, and from every source? If you play a DVD or videotape and the lines are still there, then that rules out your cable television or satellite box if you have one. However, if you find that the lines disappear when you play a DVD, I would contact the support desk for your cable or satellite provider.
2) A burn-in. This is caused by things like excessive use of video games or watching TV programs that have static (unchanging elements) like icons or scores or even lines. Have you tried using the built-in burn-in cleanup utility that is part of most Samsung plasma sets? Even if you suspect that the problem is not caused by burn-in i would recommend you try this just to see if it has an effect.
3) A problem with the electronics. Here you have to asnwer the following: is your set still under warranty? Most plasmas come with a one- or two-year warranty. If you paid for the set with certain types of credit cards, your warranty may be extended by a year or so: call your credit card.
If the set is still under warranty, immediately arrange for a repair and keep a record of all dates, names, phone numbers, and promises made. Don't accept any statement that five horizontal lines is "acceptable" to the maker; a pixel here or there may be excused but not a serious problem like yours.
Finally, if your set is NOT under warranty, consider carefully whether to make a repair or buy a new set. New set prices have dropped sharply, and the difference between a repair and a new set may not be significant. Of course, you can wait until the set fails.
thank you,
vijay
Posted on Sep 29, 2009
  • 7 Answers
SOURCE: White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Posted on Nov 02, 2009
info33
  • 72 Answers
SOURCE: Colored "snow" vertical line an inch thick on Samsung plasma
That is the sustain and buffer boards. Try to find a repair shop to repair on the component/board level because the cost of new boards out weighs the replacement cost.
Best Regards,
Beach TV Repair
Posted on Jul 04, 2010
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
LNS4695DX/XAA Samsung tv vertical and horizontal lines on picture - all components
Thats usually caused by the Tconn board and or its connection also samsungs have been plauged with tab bond issues with the LCD panel itself. Send a pic of the issue to customerservice@tvrepairworld.com and they will be able to tell you whats happening with it be sure to include the model number with the pic
Mar 13, 2012 | Samsung Televison & Video
Best Regards,
Beach TV Repair
Jul 04, 2010 | Samsung PN50A450 50 in. Plasma HDTV
I have samsung plasma tv 42" ps42c7s,have sound but dark ,no picture
Hi friend,,,
welcome to fixya
Commonly for Plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I see only horizontal line on TV Samsung CK-5339ZB
h/line is due to vertical section failure. 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. resistor R410 CONNECTED TO high voltage transformator T444 is low value resistor. .5ohm to 10 ohm. it burnt again due to short cht in vertical mainly due to ic. hope this will help. as per schematic diagram go to www.serviceinfo.com
Oct 04, 2007 | Samsung TXN3271HF 32" TV
Samsung ck-5339zb TV
only horizontal line it is a vertical section failure. caution keep brightnenn as low as possible till it is rectified & you put on tv before it this just to avoid screen burn. solution 1 check for loose contact or crack print or loose deflection coil connector. 2 check supply to vertical section. 3 check vertical ic. 4 vertical (50)Hz signalto vertical section. good luck
Sep 27, 2007 | Samsung TXN3271HF 32" TV
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
108 people viewed this question
Jerry Greenberg
Jerry Greenberg
