Question about House Brand Aqua-Pure AP102T Whole House Water Filter System
GXSF27e01 - nOT PRODUCING SOFT WATER.. Think the nozzle and venturi assembly may be dirty or plugged. How do I get the lid off?
  • Ken Emery
    Ken Emery Aug 07, 2010
    I don't know how you got an Aqua-pure whole house filter into my question, but a GE Model GXSF27E01 is a water softener, and that was the basis of my question? Review my original question and advise.
    President:
  • 2,030 Answers
That unit does not produce soft water, it is simply a whole house filter
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 07, 2010
Thermoheat dtu torpedo heater reads E1 error
These are some possible causes:
1. Wrong pump pressure
2. Dirty Air Output,Air Intake or Lint Filter.
3. Dirty Fuel Filter.
4. Dirt in Nozzle.
5. Dirty Photocell Lens.
6. Photocell Assembly not
Properly installed.(Not seeing the flame)
7. Bad electrical connection between photocell and MAIN PCB assembly.
8. Defective Photocell.
If all those check out ok, then check these:
1. No fuel in tank.
2. Wrong pump pressure.
3. Carbon deposits on spark plug and/or improper gap.
4. Dirty fuel filter.
5. Dirt in Nozzle.
6. Water in fuel tank.
7. Bad electrical connection between ignitor and MAIN PCB assembly.
8. Ignitor wire is not attached to spark plug.
Nov 29, 2013 | Protemp 125000 BTU Kerosene Forced Air...
I have very low water pressure on my 4 year old Whirlpool WHES40 Water softener when the service position. When bypassed the water in my home returns to normal. I have cleaned the venturi and nozzle and...
The pressure loss is due to either a plugged distributor/manifold or upper basket. The head must be removed for access to the manifold and upper basket. The manifold runs from the head to the bottom of the tank. This is where all the soft water is drawn from and is the most likely cause for pressure loss. Water must be shut off and tank depressurized before attempting to remove the head of softener to access these parts. Clean the slots in the manifold and upper basket. They are probably plugged with iron, resin and/or gravel and re-install.
RJ
Aug 22, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
How much dirty water should end up in the recovery tank? I'm not getting back but a fraction of the water that goes out BACK IN... It's a heated model. Is the water evaporationg or is something wrong?...
About 3/4 of the water dispensed should be extracted. If not, there are a couple possibilities. If the float assembly in the lid of the dirty water tank has a mesh filter on it, be sure there is a gap of about 1/2 inch between the top of the filter, and the bottom of the lid. Without this gap the recovery of dirty water will be prematurely stopped. Another problem could be that the pick up nozzle is not making good contact with the carpet. This occurs if the machine has been dropped on it's nose and the screws holding it firmly in place have broken loose from the plastic.
Apr 30, 2011 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
I have ready heater 150, 000 btu, the fan is blowing strong and there is constant fire comeing from sparkplug , but its not igniting. What could be wrong.
No fuel!! Several things can cause this, empty fuel tank, dirty fuel filter, plugged screen in the nozzle assembly,or plugged nozzle. So lets clean up the fuel system by first removing the top section of the heater and exposing the burner tray. Remove the tray and locate the fuel nozzle, remove the nozzle, now they say you can not clean them, I say with a q-tip, tooth pick and carb cleaner you can just be careful not to damage the nozzle. Behind the nozzle is a screen assembly these corrode at times so clean it up too. Below the nozzle assembly is the flame sensor, clean this with windex and a soft terry cloth rag, make sure it will have a clear unobstructed view of the flame.Put the nozzle assembly back together, and now inspect the fuel line for cracks, holes,and dry rot replace if necessary. Trace the lines down to the side where they come thru the case. Remove the side cover and locate the fuel line and in line filter, remove the filter. Cleaning this is easy you need a compressor and blow gun, all you do is blow air backwards thru the filter and instantly its clean. Inspect fuel lines and reassemble. Now make sure that you have clean fuel in your tank, and there is no water in it as well.Plug it in and you should now be heating like new. If not it could be your fuel pump!
Dec 26, 2010 | Reddy Heater-30-55,000 BTU Variable
Vacumm not working shampoo the rug but does not pick up dirty water
Try the following suggestions to see if you can get your machine suctioning properly:
1) Remove the Tank-in-Tank Assembly and place your hand over the motor intake valve. This valve is located next to the Floor Nozzle gasket (at the top of the Floor Nozzle window) and behind the SmartMix Bottle. If you feel vacuum-like suction at this area, your suction power of the unit is working but air is escaping at some point. If there is no suction at the motor intake valve your machine will need to be inspected by an Authorized Service Center Technician.
2) It is possible the Floor Nozzle on your machine is inserted incorrectly. This would directly affect the suction of your machine. Please follow the directions below for removing and replacing the nozzle.
Before starting, please be sure the machine is unplugged and the machine handle is reclined.
To remove the Floor Nozzle window, first detach the Phillips head screws located at the base of the nozzle. Then, remove the Tank-in-Tank Assembly. Next, pull forward at the top of the Floor Nozzle window to release the tabs of this window from the receiving holes of the machine. This window is designed to allow access for cleaning.
When replacing the Floor Nozzle window, please be sure the tabs at the TOP of the nozzle are properly inserted into the receiving holes provided. If you do not have the tabs in place properly, the suction power of the machine could be affected.
Rotate the window down into place and replace the screws.
3) Ensure that the Ready Tools knob (diverter knob) is in the proper setting and the valve opens and closes freely. Ensure the black foam gasket is in place under the valve.
4) Check to ensure the Tank-in-Tank assembly is seated properly and that it is not full of dirty water. (If this tank has a drain cap, make sure it is in place and that it has a black o-ring).
5) Check the float and baffle to ensure they are properly installed on the Tank-in-Tank. The larger square portion of this part should be below the clear baffle of the tank with the red flag portion of the float resting on top of the baffle.
6) Check the Tank-in-Tank and lid for damage. Is the lint screen clogged? Make sure the lint screen is in place on the tank lid and not placed into the motor duct. Also, clear the holes on the lint screen.
7) Check to see if the upholstery hose has suction. If the hose has suction and the floor nozzle does not, check the diverter valve to see if it opens and closes freely. This can be seen through the Floor Nozzle window as you switch the diverter knob from the floor to tools setting.
Aug 04, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
How do you clean the water intake compartment?
Hoover makes a nozzle cleanout tool just for this purpose cost is under $5. It can be purchased online at Hoover or from your local dealer.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 22, 2010 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Kenmore water softener tank flooded; no soft water
Well, there was no good solution. I capitulated and called in a professional Sears repair guy. He was as baffled as I about what was wrong. We just started throwing parts at it until the problem subsided. We finally decided there must have been a tiny vacuum leak somewhere, probably in some rubber part.
Sep 03, 2009 | Kitchen Appliances - Others
I have a Culligan Gold Series Whole House filter that is not drawing chlorine at all.
This is a Super S filter for iron and H2S removal. The venturi nozzle is plugged in the eductor assembly. It is under the chrome plate on top of valve. Put unit in bypass, run it though a quick manual cycle to relieve pressure, take the plate off, it will be plugged with oxidized iron, clean it completely, there is a screen, throat and nozzle, clean all and reassemble.
RJ
Aug 23, 2009 | Culligan Sediment Water Filter Heavy Duty
We have a GE Model GXSF27E01 water softener. It
Try looking on the computer board for a battery back up. If it does have one, unplug that and then plug it back in and see if that will reset your control.
Jul 18, 2009 | House Brand Aqua-Pure AP102T Whole House...
Hoover Upright Steam Vac, 12 amp
  • Check to make sure that the lower dirty water lid is installed and secure and not cracked.
  • Check to make sure the front duct panel is installed on the dirty water tank (this will transition the water from the front nozzle into the tank)
  • Check the filter in the dirty tank lid, clean if necessary
  • Remove the lower tank and look at the motor cover, locate a round hole, you should see a black ring (gasket).
  • with the lower tank removed, turn the machine on to check suction at the round hole, if OK then your problem will be with one of the above reasons
Jan 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
House Brand Aqua-Pure AP102T Whole House Water Filter System Logo
76 people viewed this question
Top House Brand Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a House Brand Garden Expert? Answer questions, earn points and help others
