Question about Whirlpool Duet GHW9150P Front Load Washer
I have the Whirlpool duet front load washer model #GHW91509W0 & i need to replace the front bellow seal. I have ordered the part and now I need to install it. How do I go about doing that?
  • 15,935 Answers
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn't cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Replacement: tub seal bellow/Whirpool Duet mod.#GHW9150PWO
Hi
Thanks for using FixYa. You can buy the tub seal bellow for your Whirlpool Duet from this link. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hw do I replae the washer bellow seal on a whirlpool duet washer
The following link explains step-by-step how to change the door bellow on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The first three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leak/boot tear in whirlpool duet washer
The front door seal is referred to as the "bellow". They will wear out with age and may become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or no longer providing a good seal, it must be replaced. This will cause water to puddle under the front of the washer and inside the cabinet. The following link explains how to access and replace one:
Replacement parts can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If the model number is correct, the part number is 8182119.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. In addition, overloading the washer can contribute to premature wear and tear on the bellow which can lead to rips, tears and possible dislodging from the bellow clamp seals. Always follow the manufacturer's recommendations for loading in your owner's manual.
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Replace the bellow in my front loader whirlpool washing machine
Hello. You don't need any special tools to do this. Feel around the edge of the bellows seal until you find a spring in the groove behind the face of the seal. Using a small screwdriver, lever it over the edge of the seal, and slowly work the ring over the seal face. Peel the seal off of the mounting flange, and roll it inside the drum. Remove the front of the washer, and remove the spring on the inner part of the seal. Replace the seal, making sure that it is oriented in the same manner as the one you took off. Reassemble in the reverse order. There are a number of very good videos on YouTube. Type in "washing machine repair" and you'll find different chapters in what amounts to a series on repair.....good stuff.
Hopes this is helpful to you. Best regards, --W/D-- please feel free to rate this carefully hand crafted answer! Thanx!
Aug 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi, I have the same problem on my Whirlpool Duet GHW9100LQ1.
The following link explains how to replace the bellow on a Whirpool Duet:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
The part number for the bellow is 8181850.
Searspartdirect.com carries it for about $81.
Appliancepartspros.com carries it for about $76.
Repairclinic.com carries it for $95.
Pcappliancerepair.com carries it for about $73.
Two other items you may also consider are the bellow clamps (if yours are damaged). The rear bellow clamp part number is 8182210. The front bellow clamp part number is 8182211.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Reinstalling whirlpool front load washer bellow
The easiest way to replace the bellows seal is remove the complete front panel.
This will really help: Duet front load washer repair manual
www.RepairClinic.com
Feb 03, 2009 | Whirlpool Washing Machines
Whirlpool AWM 1003 Washer - Bellows Seal
The following link gives you step-by-step instructions on how to replace the bellow:
I hope this helps you. Let me know if you have questions or require additional assistance.
Sep 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
52 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
