Question about Radio Shack Cinego D-1000 Multimedia Projector
Cinego projector dies after 3 minutes and start button turns red. I changed lamp thinking was a connectin issue since base was pulverized--but still do not shows image or sound. Do I need to send to dealer? could it cost more than a new different projector? I like cinego but do not want to spend lot more
  • 1 more comment
  • zulma_rivera Aug 07, 2010
    Need other options--just bought a new lamp that cost $200.0--do not believe I can return it now. Or can I--?Bought it from Pureland Supply
    Just want a second opinion --
    so far yes
  • 4,323 Answers
Hi
The issue you are facing is due to overheating of the projector or due to the end of lamp's life. To be sure check the vents of the projector, you should be getting hot air. If not then it is an issue with the fans not working and you'll need to get the fans replaced. Howevre, if the fans are working but the flow of air is very less then try cleaning the filters.
Also, check how many hours has lamp crossed. Lamp has a very limited life and after this you would require to replace it. Go to Main Menu-> settings-> check for lamp hours. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 07, 2010
    Daniel
    Just checked the fans--and only one is working during the first 3 minutes of start up. It seems that it could be the problem. Where are the filters located?
  • Daniel Scott
    Daniel Scott Aug 07, 2010
    The filters are on the side and are removable. Try if you can remove the filters by sliding, if not then you'll need to disassemblt the unit to clean the filters. And the issue you are facing is due to overhaeting, please get the fan repaired/replaced.
    Daniel
  • 787 Answers
I recommend buying a new one since the projector repairs aren't easy at all and are also very expensive. Also, you can't be sure it will work just like new after you get it back ... that's what happened to me, I had to send it 3 times until I finally bought a new one.
  • Tudor Valean
    Tudor Valean Aug 07, 2010
    Yes, you can. For expensive parts, they accept returns.
The lamp of my optoma hd80 shut down after 20 minutes. The lamp indicator problem light on. My lamp as only 880 hours. Do i have to change the lamp now?
Hi Pierre,
Did you resolve this issue. I am facing a similar on. After a few minutes, the lamp shut down and the the red lamp light turns on. I was thinking it is an overheating issue.
Regards
Ludovic
Mar 25, 2010 | Optoma HD80 Projector
My cinego projector turns on but then off? why? the main logo "cinego" comes on , and by the way the lamp is good i check it? what else can be wrong with it?
Be very careful how many times you press the power button. Cinego has a tendency to have a slight lag when turning on. So press the power once then again after 2 seconds.
Aug 11, 2008 | Radio Shack Cinego D-1000 Multimedia...
Flashing red light
sounds like a flaky power supply or lamp ballast
Jun 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego d-1000 after 3 minute turn off
Hi Rcasso
There could be a whole number of things that is the cause.
The most popular of which would be replacing the lamp or Ballast ( lamp's powersupply )
Could you supply me with the LED status when the unit shuts down ?
Apr 29, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego turns itself off after 10 mins
Hi There
Check if your lamp has any faults like discolouration or marks on it.
Otherwise it could be Mainboard that will need repair or replacement.
Apr 16, 2008 | Radio Shack Cinego D-1000 Multimedia...
CINEGO
Mine does the same thing and I just replaced the bulb after waiting almost 6 months and I purchased one directly from Radio Slack. It will turn on for about 10 seconds and then goes into shut down.....At three hundred dollars I can't see putting another bulb in, when this one has less than 50 hours on it.
What do you think
Oct 29, 2007 | Radio Shack Cinego D-1000 Multimedia...
Cinego Automatically shutts off after 15 seconds
had the same problem - replaced the lamp even though it only had 632 hours on it. seemed to fix the problem - 10 hours and 4 moves later still doing ok
Jun 12, 2007 | Radio Shack Cinego D-1000 Multimedia...
Auto shut off
Same problem for me with a new lamp and it shuts off after 10 seconds or so.
I have been unable to get an answer from anyone....hopefully someone here can help
Feb 17, 2007 | Radio Shack Cinego D-1000 Multimedia...
79 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
