Question about Hyundai Electronics E320D 32 in. LCD Television
I want to use my dish network remote to turn on my Hyundai 320 tv. I can not find the code, and it is frustrating. Thanks for the help.
    Novelist:
    Champion:
  • 286 Answers
If you have not gotten this resolved, follow the link below, it will help you out. The link will walk you through a power scan, which scans the codes on the tv until the correct one is found for the remote. If a code has not worked in the past, this will work much better. I hope it helps you.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Posted on Jan 20, 2011
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I am trying to set a dish network to control my samsung dvd-1000 and a daewoo tv
Hi henry walters,
I know it can be frustrating trying to get the codes to program equipment. You can view the link below to search for any codes you may need for your equipment!
Link: http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx
Let me know if you have any other questions!
Tommy Faust
DISH Internet Response Team
Nov 29, 2011 | DISH Network IR Remote Control
Remote control code
thegoi_16
I can provide you with instructions and codes for DISH Network equipment. I have provided a link with this information. If you have DISH Network equipment, select your receiver model and follow the instructions. At the bottom of the page are links for your receiver model with the TV codes for programming the remote. I hope this helps.
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Mar 03, 2011 | Televison & Video
Recently moved to another city, lost the remote and can't find the code to program the DISH Network remote to get my tv off channel A 4
Hi my nameis Mike Houston of DISH Network and I was going over your post and see youmoved and lost the remote. We have what we call a Power Scan for the DISHNetwork remote; it will allow you to get the code to the TV. http://www.dishnetwork.com/SupportSection/power-scan-instructions
Aug 28, 2010 | Initial HDTV-320 32 in. LCD TV
Have to manually turn on tv when turning on digital converter box
astoner3,
Our dish remotes are compatible with most TV manufacturers. On some older TV, we may not have codes that allow for full functionality for the DISH remote. I have provided the most common codes to work with the Sharp TV. The codes are: 628, 605, 740, 591, and 606. I have also provided instructions on programming the remote to the TV.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
May 15, 2010 | DISH Network EZ Remote Remote Control
I need a satellite Bell express Vue code (3100) I can't use the remote control Dish!!!!
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Jan 23, 2010 | DISH Network IR Remote Control
Need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
Jun 02, 2009 | DISH Network IR Remote Control
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Programing Dish Network Remote to control a Vizio Tv.
Try 627 for Vizio TVs - that should work on the Dish remote.
Dec 22, 2008 | DISH Network IR Remote Control
Elements TV need code
the new element television I purchased listed codes in the manual (on the back or as an insert) for dish network. Worked on mine.
Apr 11, 2008 | Televison & Video
Hyundai Electronics E320D 32 in. LCD Television Logo
109 people viewed this question
Top Hyundai Electronics Televison & Video Experts
Tom Chichester
Are you a Hyundai Electronics Televison and Video Expert? Answer questions, earn points and help others
