Question about Smith AO Pool Pump Motor
1.5 hp motor just hummed. Removed start cap and pool store only had a used one that they said worked to the best of there knowledge. Installed it and it popped and tripped c/breaker. installed old one and it was quiet for two to three seconds and then popped and tripped the c/breaker. Did I ruin my motor?
    President:
  • Smith Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
The cap would not ruin the rest of the motor on its own. It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 17, 2010
I had a hayward 11/2 hp 2 sp...I put a AO 2 hp 1 sp on my ing. pool and how it just hums and shuts off. I checked everything out and primed it before I tried to start the pump. Can anyone help
Turn off the power and remove the end cap at the center back end of the motor. The end of the motor shaft is then exposed and you can use a 9/16" open end wrench to verify that the motor shaft is turning freely.
If it offers resistance the pump needs to be opened and checked to find out why. If it does move freely, take it to a pool store or motor shop to test it. Rarely, a motor gets out of the factory DOA.
Jan 19, 2013 | Pool & Spa
I have a brand new 1 1/2 hp superflo. I wired it in and turned on the power, it hummed for a few secounds and trip the breaker. now it it wont work and just immediatly trips the breaker. Any ideas as
It sounds like the motor shaft is stuck. The back end of the motor has an end cap that comes off so you can access the end of the motor shaft. Try this with the power off; Remove the cap (center rear of the motor),Using an open ended 9/16 wrench you should be able to turn the shaft back and forth. A motor that has sat for a while will sometimes act like yours did. A nudge with the wrench usually breaks it free. Remove your wrench and turn pump on. If it still won't start the motor may be defective.
Dec 28, 2012 | Pentair Superflo 1 1/2 Hp In Ground Pool...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Motor was humming move contacts worked for few days turning on and off.The motor will not hum or come on. I think it is the start cap.
MOTOR SHOWN IN PICTURE HAS A RUN CAP.IT HAS NO START CAP(ONLY 2 SPEED DO) WIRES AND TERMINALS MUST BE CLEAN , USE SAND PAPER AND CLEAN THEM UP. LOOK AT THE WIRES IN THE BACK OF THE MOTOR ALSO. USE A VOLT METER TO CHECK FOR POWER SEARCH YOUR ZIP CODE FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING. BRING THE CAP IN FOR TESTING.. GOOD LUCK
Sep 14, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
I have a 18 year old dura-glas pool pump. Recently, when turned on, the pump sometimes just 'hums' for about 3-4 seconds, then starts. The pump is primed and does not leak. There are no obstructions...
SOUNDS LIKE THE START SWITCH IS DIRTY OR IT MAY NEED A CAPACITOR it's a 161start cap THIS IS HANDS DOWN THE BEST PUMP YOU CAN HAVE ! THESE AS ALL PUMPS CAN BE TRICKY TO WORK ON, THIS COULD HAVE THE MOTOR REPAIRED WITH NEW BEARINGS AND A SHAFT SEAL AND DIFFUSER ALL FOR ABOUT 100.00 .. LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY OR SHOP.. USE YOUR ZIP CODE IN YOUR SEARCH .. GOOD LUCK AND VOTE .. Jay
Jul 28, 2010 | Sta Rite StaRite Duraglas Pump 1 12 HP...
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Motor hums won't start. I tried to seperate motor from pump, but could not uncouple. Was checking for impellor jam. what next
sounds like you have a bad start capacitor, check that first and make sure the motor spins freely. You may be able to check to see if the motor is seized by removing the end cap and spinning the shaft. If it spins freely, it's a bad start/run capacitor.
Jan 24, 2010 | Hayward Northstar Pool Pump 2 Hp Sp4020ns
I have a 1.25 hp motor for my pool. When I turn on the electric switch, the motor hums but won't turn. I have to take off the end cap and use pliers to get it to start. Does it need to be replaced?
It's most likely the centrifugal start switch malfunctioning. It's stuck or, has burned contacts or, loose spring or, it's broken. It's right on the end of the shaft on the back end of the motor.
Often it just needs the contacts sanded and/or the the moving parts lubricated.
More info, let me know.
Charlie
Aug 25, 2009 | Pool & Spa
My Mustang pool motor by Waterway musts-120 is just humming when it is turned on. It is connected to a timer, but the pump is working fine, just the motor is humming. What do I do? Is my motor toast?
Check your loacl yellow pages for an electric motor repair shop. They may find it is fixable but could at least tell you if it is salvagable or not. Some even carry replacement motors at costs lower than the pool stores.
Jun 10, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
220 V Single phase/cap 4hp two speed A.O.Smith motor problem
It is a capacitor problem. Motors use capacitors to start. Your 2 speed motor should have 2 capacitors (or 1 capacitor with more than 2 connections). Changing this capacitor should solve your problem.
Apr 05, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Smith AO  Pool Pump Motor Logo
110 people viewed this question
Top Smith Pool & Spa Experts
Mike Squire
Jay Finke
Jay Finke
Paul Carew
Are you a Smith Pool and Spa Expert? Answer questions, earn points and help others
