The solution to this is to unplug the batery from the player itself. you have to open it by taking a jewellers screwdirver, pry out the rubber cover from the back. it is the only one that is on the battery cover. after doing so it will reveal a philipps head screwdriver. simply unscrew it and unplug. be very careful and pry the sides of the battery cover slowly sliding and prying downwards.. unplug and plug back in again.
the solution to the other problem here is that you guys and gals are unplugging the player prematurely meaning. You just simply unplug it from the your computer w/o safely removing your hardware. by doing this straight unplugging from the pc, yu are corrupting the hard drive on your usb and eventually end up breaking it.
My insignia NS-2V17B when I turn it on, it says building library and does not finish to come up, what can I do please??
Have you made sure it's charged? when you plug it in with a USB it should automaticly come on because it is connected
Ok i have the same problem it'll come back on just hold it for a LONG time and eventually it'll turn off and come back on
insignia NS-2V17b is froze and will not come back on
Frozen in "Bluetooth initialized" mode.
I turned on my Insignia NS-2V17B and my Bluetooth Headset and the MP3 player froze. I can't get any of the buttons to work, and it won't turn off. To answer the expected question of, is my "lock" switch on, the answer in NO. Also, I can't get the bettery cover off.
Josh
my insignia mp3 player won,t come on
