Modems
Problem for Modems
Generic problem for all Modems
Dual Routers?
By VideoMaster on Apr 27, 2008
I have a small home network on a Linksys router (4 port+wireless).  My new ISP uses an ADSL modem that is also a router (2 port).  I connect using PPPoE configured on the modem/router.  Both devices default to 192.168.1.1
What's the best configuration so I can have four DHCP ports and wireless?
Thanks!
-Andrew
Solution #1
posted on Apr 29, 2008
Not Rated)
Al42
Rank: Wiz
Rating: 81%, 31 votes
Disable DHCP on the router and connect the modem to one of the router's LAN ports - that will give you 3 DHCP ports + wireless. If you need more than 3 ethernet ports, use a hub on one of them.
Was this helpful?
Yes
No
Solution #2
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Disable DHCP in the router. Connect the modem to a LAN jack on the router. You'll have 3 LAN ports. If you need more ports, buy a hub. (You can change the default IP address on the Linksys, but you can't forward through 2 NATs.)
Popular Solutions for Modems
Questions and Unsolved Problems for Modems
Answer
What does it mean when the DS light contiues to flash
Answer
How to enable NAT on Zyxell P600 series modem. As im not able to connect to other people online.
Answer
will not link up with main unit. tried several times using the print out of codes provided by main... (More)
Answer
I am having compex modem. Often in my modem data light alone blinking very fast and link,data lights... (More)
Answer
I have a 3G Alcatel speedtouch X020 Modem, it works with Vista 32 but not with vista 64 or win7 64.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Modems Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
