Question about Microsoft Xbox 360 Console
Turn on 360 controller green light flashes and no picture
  • 767 Answers
If you mean there is no video then the problem
if somewhat common . There are several ways to
fix this .
First is the longest lasting repair will require
to have a shop re-flow the G.P.U. I also like to
install a G.P.U. clamp , as hardware up grade
witch keeps the G.P.U. connected to the board.
Second is a DIY /guide . I don't recommended this
repair unless you are desperate for a working box
right away. This repair isn't very durable .
Rob
Posted on Aug 07, 2010
3 Suggested Answers
SOURCE: Flashing Green Light
your xbox might be downloading a game that you ask to download or some other type of media. to chick turn it on and go to active downloads and see.
Posted on Feb 09, 2009
ChobPT
  • 220 Answers
SOURCE: wireless 360 controller not working
Your solution can be found at http://support.microsoft.com/kb/906947
Posted on Jun 21, 2009
My XBOX 360 will not turn on. The power bar has a green light but pressing the eject button or power button on the console will not turn it on. We have tried plugging it in to a different outlet but that...
Hi christoph52893,
If the Xbox 360 power supply light is green, this means the Xbox 360 power supply is ok and it is an issue with the console itself. You will need to contact Xbox 360 customer support to service your console. However, if you have a flashing orange or yellow light, it means that your console is fine but instead there is something wrong with your power supply. It indicates that it's not getting enough power.
Hope it helps.
Thank you for using FixYa.
Jul 05, 2011 | Microsoft Xbox 360 Console
My xbox 360 will no longer work i plugged it in yesterday and the green power light in the middle came on but i got none of the flashing green circling lights that appear just before it gets to the...
The flashing lights on the outside of the green power button are the status lights for any connected controllers.
Just turn on one of your wireless controllers and the green status lights should come on.
If you turn on a controller and it doesn't automatically connect, press the connect button the top of the controller and front of the Xbox at the same time. This should connect the controller.
Mar 05, 2011 | Microsoft Xbox 360 Console
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Feb 02, 2011 | Microsoft Xbox 360 Console
When I try to turn on my xbox 360 my controllers do not connect to it. I get the green power light on the front of the xbox 360 and four flashing green lights on my controller. I have tried my...
Press the circle button in front of your xbox 360 and at the same time press the small circle button on your controller ( located near the port where you connect the play and charge kit cable) so they can sync with each other
Sep 16, 2010 | Microsoft Xbox 360 Console
Ring of light has 4 quadrants flashing green - no picture on TV
Red Lights are a problem for Xbox 360, however green light problems are hard to find, still you can try following steps to check where the problem lies
1) Boot with no HDD and see if that helps.
2) Also remove all your inputs in the back, and reinsert them. Make sure your HDMI/VGA/Compenent input is plugged in correctly.
3) Try switching the output from HD to SD, if you have a HD VGA Cable for your Xbox 360
4) Turn the Xbox 360 off, turn it on with the controller, as it turns on hold the Y button and the Right Trigger, this will put all audio/video settings to default.
If the above given steps do not help, kindly call Microsoft Support and try to get an answer from them to this issue, and if required you may have to send your console for repairs.
Dec 07, 2009 | Microsoft Xbox 360 Console
My wireless cntroller will not flash its green center lights
sounds like.... the battery completely died on controller.. you charged it by plugging it in to system and never restarted the system to regain the wireless signal..
turn off 360... turn off controller.. boot system.. boot controller, if no signal is detected you have a hardware issue with controller (assuming other controllers work with system)
Aug 24, 2009 | Microsoft Xbox 360 Controller
Green light flashing on controller no light on 360
You need to reconnect your controller to your xbox. Next to the two memory slots on the front of your xbox, there should be a small round button. Turn on both your controller and your xbox. Push the little round button. There should be a similar button on your controller. Push that too. They should recognize each other.
Jun 27, 2009 | Microsoft Xbox 360 Controller
Controller will start up the 360, then just flashes. Wont respond
Remove the batteries from the controller for a few minutes to reset it then try again.
Jun 03, 2009 | Microsoft Xbox 360 Controller
Wireless controller
press the little buton on the controller and the xbox and it should register
Apr 26, 2009 | Microsoft Guitar Hero: Aerosmith with...
Microsoft Xbox 360 Console Logo
139 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
