Question about Labtec Pulse 475 Computer Speakers
The right speaker output does not work! what to do?
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
May 08, 2011 | Audio Players & Recorders
@I got a bose acoustmass 7 it has three inputs left right center,and three outputs left right center dont have paper work I need like a diagram or instructions on hooking it up please help.
you need to run the left speaker output from the amp to the left speaker input on the Bose, the right speaker output on the amp to the right speaker input on the Bose, the center channel output on the amp(assuming it has one), to the center channel input on the Bose...then the right output on the Bose , to the right Speaker..the Left output on the Bose to the left speaker...and finally the center channel output on the Bose to the center speaker
Jan 07, 2011 | Bose Acoustimass 5 III System
No Right Front Speaker Output
Swap speakers over...check the balance isn't fully to the other channel...swap left/right phono cables over (if thats how your using it) other than that i would say is broke.
Easy way to check speaker cable/speaker... touch a small battery (like used in a remote) across speaker wires, you will hear and see the speaker cone move.
Aug 07, 2009 | Audio Players & Recorders
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
No output from right side speaker jack
audio board located inside the mainboard console to the right trace your speakers wire to bd, disconnect the three leads, 3 phillips screws, and examine bd for burns. If yes, ebay the board id for a replacement.
Apr 24, 2009 | Dell W4201C 42 in. Plasma HDTV
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Dec 02, 2008 | Logitech X-530 Computer Speakers
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
Speaker Problems
Can you swap speakers and see if the left working speaker works when plugged into the right output?
If it does, then your right speaker is bad or the right speaker cable/plug may be bad.
If the working left speaker doesn't work on the right output, then I would suspect a problem in the right channel audio amplifier.
Please let me know if I can be of further assistance to you.
- Jim
Feb 29, 2008 | Emerson MS3100 3-Disc CD Changer
Labtec Pulse 475 Computer Speakers Logo
Top Labtec Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
