Question about AO Smith 1 hp 3450/1725rpm 56J Frame 230 Volts 2 Speed Swimming Pool Pump Motor - Electric Motor
I replaced my motor 1 yr ago and all worked fine...now the low speed works but the high speed only makes a humming noise.
  • AO Smith Master
  • 1,384 Answers
SOUNDS LIKE A DIRTY START SWITCH OR CAPICITOR. THES MOTORS ARE NO JOKE AS I'M SURE YOU ARE STILL FEELING THE PAIN OF THE PURCHASE PRICE.. LOOK FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING ,USE YOU ZIP CODE ..
I WOULD HAVE THIS TYPE OF MOTOR SERVICED EVRY YEAR ! 1ST TIME ABOUT 80$ NEXT YEAR 40$ WHAT I CHARGE..
DON'T TAKE THE CHANCE HAVE A PRO LOOK AT IT, THERE TOO EASY TO SCREW UP .$$$... IF YOU UN-HOOK THE WIRES TAKE PICTURES OR WRITE DOWN WERE EACH ONE GOES !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!BEST OF LUCK..
HOPE I WAS OF SOME HELP, VOTE IF'N I WAS
Posted on Aug 07, 2010
Capacitors e185116
It's a good motor. How do change the speeds? If you have it on a dimmer switch,that's your problem.
Jun 02, 2013 | Emerson Fans CF452BS Ceiling Fan
Maytag top load will not agitate and only spins on delicate cycle
could have a bad motor,there are two sets of windings in the motor or low and high speed.the delicate works on the low speed and everything else works on the high speed winding,you can check with a meter to make sure 120 volts is going to the motor.sometimes the motor will just hum and nothing else.you'll have to look at the wiring diagram to see what color wires are going to the high speed winding,if 120 volts is coming down but nothing happens you have a bad motor.
May 10, 2011 | Washing Machines
I have a Waterway Spa Pump Executive 56 Frame 4hp Dual Speed PF-40-2N22C in a Catalina spa that recently developed an issue. The pump will not start in low speed, just makes a humming noise, but it will...
the problem with the sound is the bearings inside the motor are going out. i have the same pump and i have to replace the motor. replacing the bearings is very hard and will cost you about the same after you carry the motor and new bearings to a shop to be pressed in. hope this helps!!
May 04, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
High speed on pump motor just hums then trips breaker. low speed works fine.
possibly trying to draw more power than the breaker and wiring are rated for.. check maximum amperage draw from motor, then check breaker.
If breaker is rated lower than High speed amperage draw, then have a qualified electrician install proper size of wiring and breaker.
If not, then the high speed coil of motor may be defective, check for warranty of unit.
Jul 30, 2010 | Jacuzzi Bellavista 6 Whirlpool w/2-Speed...
Blower does not activate when a/c mode but works fine without a/c
on your fan motor. red is low speed ,blue is med speed, black is high, red for heating . blue works good for cooling. black is high speed. re look where the forth speed was hooked up. put blue there.
Apr 16, 2010 | Honeywell L4064B2236 Fan/Limit Control...
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
1997 Civic LX A constant mid-high pitched humming noise?
Have you had the water pump replaced yet? Could possibly be the water pump making noise because it's about to go.
Nov 08, 2008 | 1995 Honda Civic
JACUZZI HOT TUB J365
Hi JOEY JIGSAW,
I'm Harvey the Master Plumber.
Your problem is: 2ND MOTOR ON TUB IS HUMMING BUT NO WATER MOVMENT REPLACED WATER TODAY #1 MOTOR IS WORKING IN LOW AND HIGH SPEED BUT #2 MOTOR IS NOT KICKING ON
Definately an electrical problem. First check the switches, if you find a bad switch replace it. Check the wire connrctions. A bad connection will cause great frustration. If you've been carefull with the first two steps and it's still not working it's time to see if # 2 motor has siezed up. Do this only if you know what you're doing. It requires disconnecting the wires to the motor and applying 110 volts from another source directly to the motor wires. If the motor just hums and gets hot, it's time to replace it or take it to a small motor repair shop. It might be wise to check the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 06, 2008 | Home
AO Smith 1 hp 3450/1725rpm 56J Frame 230 Volts 2 Speed Swimming Pool Pump Motor -  Electric Motor Logo
117 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
