Question about Canon CanoScan 8600F Flatbed Scanner
Canoscan 8600shows "lamp warming" message, and doesnot scan beyond retracted position. Lock had been left in unloc position while transported.
  • kaybill Aug 07, 2010
    yes, I waited for a very long time for the "warming" message to disappear. The scanner seems to be trying to move repeatedly,but cannot. It had been handled considerably in a long distance move,and when I started to hook it up I noticed that the lock on the bottom of the scanner was in the UNLOCK position.
    Lamp is working. Scanning mechanism seems to be advancing 3 or 4 mm, and then bouncing back and forth interminably.
  • Canon Master
  • 3,866 Answers
Its is verry possiable the motor on the carriage is jammed or stuck into hold posiation or might have been broken in transport it is really difficult to say from my POV "point of view" What I recommend is seeing if the motor is not just stuck into home position this will take a little surgury on hte unit that most end users are not faired to do so do nto shoot the messenger here. But your going to need to go inside and try to move the carriage to free the motor if the motor does nto seem to move then you might have a burned motor on the carriage,
let me know
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 07, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Aug 08, 2010
    This would be the motor or gear stuck it should not be bouncing back.
  • 506 Answers
The POST was not completed. Replace the lamp.
  • 787 Answers
Have you waited for the "Lamp warming up" message to disappear?
Why do I get an error message: Internal error occurred. Scan driver will be closed. Code:5,202,52?
Look at the bottom of the scanner and there should be a lock/unlock slider. Unlock it and see what happens.
If it is already unlocked then the drive/stepper motor or belt is bad.
Mar 27, 2015 | Canon CanoScan LiDE 25 Flatbed Scanner
My canoscan 8400F suddenly stopped working last week. I had been scanning slides thru Photoshop when on my next scan attempt, I got this message: Cannon scan for these reasons: -The original may not...
You have to remove the white protective sheet from the the lid. Once you remove it you will be able to scan film. Also make sure the lock button is not in the lock position.
Open the Canoscan Toolbox.
Click the Save option.
Put a check in the box that states "Display the Scanner Driver".
Click Scan.
Click the Advanced Mode tab.
Make sure Select Source is set to "Platen".
Click the Preview button at the top left
Another thing is this can be caused by a faulty FAU cable. One or more of the eight wires within this cable has fractured
Oct 16, 2010 | Canon CanoScan 8400F Film Scanner
Xerox C20 displaying "Scanner Locked" message. Won't copy.
  1. Press the power switch to the OFF (O) position. The power switch is located on the lower, left side of the machine.
  2. Pull the scan lock switch toward the front of the machine to unlock the Scanner.
    NOTE: The scan lock switch is located on the bottom of the Scanner Module. Make sure the scan lock is completely free. It sometimes hangs at the halfway point.
  3. Press the power switch to the ON (|) position. A 'Warming Up, Please Wait' message will be displayed on the Display Screen. Warm up time is less than 40 seconds from power ON and less than 25 seconds from the Power Saver mode.
Aug 30, 2010 | Xerox CopyCentre C20 Black and White...
CanoScan 8400F Cannot scan for these reasons: -The
You have a bad scanner lamp, but they are not available as a spare part.
Nov 14, 2009 | Canon CanoScan 8400F Flatbed Scanner
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Cant find lock switch for canoscan 8000f
The bar is locked in the a protected position. That the bar tha moves across the scan.. To unlock the scanner, find the lock on the back of the scanner, remove the tape securing the lock, and pull up on the lock. Rate this with 4 diamonds before logging off.
Mar 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
BROTHER MFC-8840D "Check Scan Lock" error message
I had the same problem. It means the scanner lamp is in the park position and is stuck. You need to lean the printer away from the sheet feed side and bump it on the side. This may fix it. If it doesn't turn off the power and remove the two screws that hold the scanner lid on. Then remover the other 6 screws located under the lid on the left side while the lid is hanging from lid open sensor cable be carefull not to drop the lid, break the cable or the glass bed. After removing the base screws you can set the lid on the scanner again while you lift the scanner bed exposing the scan lamp mechanism. Push it a few inches in the machine and close the lid. You can do a test by powering the unit on and hold the lid open sensor button located on the bottom left of the lid. The system should initialize and bring the scan lamp back to the proper position. Turn off replace all screws and your done. If it doesn't work the first time push the scanner lamp farther into the scanning area and repeat. Good Luck
Oct 05, 2008 | Brother MFC-8840D All-In-One Laser Printer
Scanning problem
Are you talking about the switch to lock the carriage during transport? If so, this should not be on during usage.
Lou
Aug 23, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Installation
An error occurred when you set the transportation lock to the lock.gif locked position. To clear the error message on the LCD panel, set the transportation lock to the unlock.gif unlocked position, and then turn on the product again or press the fontx1.gif B&W Start or fontx1.gif Color Start button to restart the scanning job.
You can find the transportation lock on the left hand side of scanner when you lift/tilt ADF up. Hope this helps...
Apr 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
Canon CanoScan  8600F Flatbed Scanner Logo
old marine
old marine
