Question about IBM Computers & Internet
R50 will not renew ip address - IBM Computers & Internet
    President:
  • 1,768 Answers
1. Login to router first and verify that the router with the rj45 cable.
2. Go to the DOS window and then type "cmd" then type at the prompt "ipconfig /all". this will show the network connections but look at the wireless connect and the ip and MAC address.
3. Disconnect from the RJ45 ( Ethernet cord) then reboot the PC or laptop.
4. check laptop for IP address from router.
5. At the dos prompt do a ping >> www.yahoo.com
example: ping www.yahoo.com
Posted on Aug 07, 2010
Reset ip address
If you use DSL or a cable modem you could try (as mentioned above) resetting your IP address. Go to the RUN command, type "command"
There you can type:
/ipconfig
(shows your current IP)
/ipconfig /ALL
(more details such as when the current IP "lease" expires)
/ipconfig /renew
(renews your IP address)
/ipconfig /release
(drops your current IP)
Bell High Speed users need only reset the modem to obtain a new IP. You can check your current IP address from http://www.ip-details.com
IP Details com Find your IP address Information
Jan 14, 2014 | Lexmark E260dn Laser Printer
Tip
Windows XP: How to release and renew IP addresses
IP addresses can either be assigned manually or automatically. When they are assigned automatically, a DHCP (Dynamic Host Configuration Protocol) server hands them out and determines which computer or other device gets which address. This process usually flows smoothly, but there are times when you may need to release or renew an IP address even when using DHCP.
There are several ways to release and renew IP addresses in Windows XP. Each procedure is described below.
From the system notification tray:
1. Right click on the network connection icon in the system notification tray.
2. Select Repair. Windows will automatically release the current IP address, reset the network connection, and request an IP address from the DHCP server. (The new IP address that gets assigned may be a different one from before, or it may be the same one.)
From the Start menu:
1. Click the Start button.
2. Right click on My Network Places.
3. Select Properties.
4. Right click on the network connection that is currently in use.
5. Select Repair. (If you choose a network connection that is not in use, Repair will be grayed out.)
For either of the above methods, you can release and renew your IP address manually by clicking Disable instead of Repair, and then right-clicking and choosing Enable.
From the command prompt:
2. Click Run.
3. Type "cmd" and press [Enter].
4. At the command line, type "ipconfig /release" and press [Enter].
5. Type "ipconfig /renew" and press [Enter].
6. Type "exit" and press [Enter].
on Feb 02, 2011 | Microsoft Windows XP Home Edition
Renew ip address
To renew your IP address in Tablet:
Remove the SIM card and then insert it (or) reset the WiFi if it is a Dynamic IP address it will get change.
Before and after changing check the internet IP address from the site IP-Details.com .
Jun 30, 2013 | Tablets & eReaders
Renew ip adress
OK. You need to reset the modem to renew ip address from the current one.You can't reset the ip address using the router reset method.So reset or switch off the modem and then switch on it.Then new dynamic ip address will assign will be generate for your connection.Check ip address using the site Ip-Details.com before and after resetting modem...I hope you will get the answer by my reply.
Jun 15, 2013 | TP-LINK Computers & Internet
How to release and renew the IP address in Win Xp.
Go to start
Go to run
type cmd
to renew the IP command is
ipconfig /renew
to releaed the command is
ipconfig /release
May 03, 2010 | HP Pavilion dv6000z Notebook
How do i renew the ip adress for my linksys router ?
Goto your web browser.
Enter 192.168.1.1 and put admin for both username and password.
The admin screen for your router should have a MAC address clone feature. If you enter the MAC address (which is found on the main page of the admin screen) and change the last two boxes, it will renew the IP address. Don't change the first 4 of the mac. When putting different numbers in the last two, it has to be hex (1-8 for first digit and a-f on the second digit).
Hope this helps,
Mar 05, 2010 | Linksys Wireless-G WRT54G Router
What's an IP address?
internet provider address. ring your provider and they will sort it
May 24, 2009 | Acer Aspire One PC Notebook
Cannot renew ip address
You may have to perform a DNS Flush..Sometimes with wireless, the laptop cache in the IP address that is used when you are connected wirelessly. You can Flush this down the toilet by performing the following command at a DOS Prompt by going to run, and type in CMD, then input the following command in. Once this is done, try to renew your IP again!!
C:\>ipconfig /flushdns
May 12, 2009 | Computers & Internet
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically
Oct 28, 2008 | Gateway Computers & Internet
How do you renew your IP Address?
Goto start > click on Run > type 'cmd' > now when you come to dos prompt type "ipconfig /release " and then hit the enter key..Now type "ipconfig /renew " this will renew your ip address..If you want to change it manually then goto internet connection > select internet properties > open Tcp ip properties.You will get a dialogue box where you can change your ip address if it is assigned manually...
Regards
D I L I P
Oct 28, 2008 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
