Question about Kenmore Dryers
How do i replace a kenmore dryer model 11076430110 door latch?
  • Kenmore Master
  • 8,220 Answers
Just remove the old part and snap the new one inhow do i replace a kenmore dryer model 11076430110 - f3cdeac.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 07, 2010
Kenmore he5 dryer doesn't run, have power, door switch works, thermal fuse, have continuity?
What does the display say? Typically, these Kenmore dryers don't run because of a door latch error. We have had to have our door latch replace 3 times in 3 years. There is a lengthy trouble shooting program to bypass the latch error but it is time consuming.
Oct 15, 2014 | Kenmore Dryers
Kenmore smart heat dryer not starting have one beep and click
Hi John , sounds like you need to replace the door latch , your going to need the model # to order the correct part .GOOD LUCK APPLIANCES R EN
Apr 26, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer model number 86860100
door latch kit 279570. repairclinic.com has picture of it
Oct 13, 2013 | Dryers
The door pops open after about 10 seconds. We have replaced the sensor that is located on the upper left inside of the door, to no avail. Any ideas? Also, I am not sure if this is the model #..
either the hinges have gotten bent from too much weight being put onto the door when it was open or your door latch might be broken, see if the white plastic door closer on the top inside of the door catches onto the gold colored latch that is at the top part of the dryer door opening, if either one of these are damaged you would replace both as they come as a kit. here is a parts listing:
http://www.repairclinic.com/Kenmore-Dryer-Latch-Parts?z=100
Nov 25, 2010 | Kenmore 600 6965 Electric Dryer
Dryer door
The dryer door catch and latch assy is worn and needs to be replaced.
See this link to see which of them matches your dryer: http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Door-Latch-Kits/index.aspx
Any local appliance parts supply center will have this part in stock. It is howe3ver best that you take your "complete model number" with you when you go to get the replacement part. They are under $3.00 in
cost.
Use a knife blade to unlock the opposing plastic retaining tabs on the old part for removal. Make sure you change both pieces. The one in the chassis and the one in the door.
Thanks for using FixYa.
Kelly
May 16, 2010 | Kenmore 63942 Dryer
I HAVE A KENMORE 90 SERIES AND THE DOOR KEEPS ON OPENING, SO I TOOK ALL OF THE CLOTHES OUT TO SEE IF THERE WAS TO MUCH IN IT, AND EVEN WITH NO CLOTHES IT OPENS?? IT DOSENT APPEAR ANYTHING IS BLOCKING THE...
Inspect the door and when you open it, does the latch hold the door closed? If not the dryer door / latch may need to be replaced.
But check the door as it opens... the door hinges may have been damaged, causing the door to not close properly and the latch may not be damaged, only the hinges.
Good Luck!
Jan 03, 2010 | Kenmore 62602 Electric Dryer
I DONT KNOW HOW TO REMOVE THE OLD LATCH FROM MY KENMORE DRYER DOOR. I REPLACED THE STRIKER PIECE BUT CANT GET THE OLD LATCH OUT.
the door has screws all around it,you can remove a half to get to the latch,let me know-mike
Mar 30, 2009 | Kenmore Dryers
Kenmore gas dryer model 97284100
The door latch is about $5. Replace it.
Any appliance parts store has them.
Mar 27, 2009 | Kenmore Dryers
Kenmore Dryer
check also,
  • the other ends of all cables connected to the relay,
    if the other end of any part of the latching circuit has loosened, the relay will not latch closed when the start button is pressed.
  • Door Switch, it is part of the latching circuit
Sep 21, 2008 | Kenmore 62872 Electric Dryer
Dryers Logo
53 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
