Question about Ovens
AEG Oven The oven has stopped working. The fan does not work, & the oven & grill do not heat up. The control panel is powered & the orange light is on. I'm not sure whether or not the red light which controls the temperature is on. Any ideas what the problems is? The oven is an AEG Competence 3032B
  • niamhcarroll Dec 17, 2008
    The oven or grill stays on for 20-30 mins and then goes off, the orange light is still on. The oven stays off for 10-20 mins and then comes back on for 10-20 mins. Any ideas what the problem can be?
  • Anonymous Mar 22, 2014
    aeg competence b6100-1 needed to power off to stop cooling fan, now on power up, there is zero response from control panel.
  • 134 Answers
Probably there is an electrical relay that has failed.. or if electronically controlled, the equivalent circuitry. Or maybe a thermostat has failed. Be careful with anything electrical, as these kinds of faults may need a trained tradesperson. They can be dangerous to play with, as you need to be able to take electrical measurements and use tools to repair this yourself.
Posted on Apr 30, 2008
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
Aeg competence d8800 5
Electronic component failure. As only 5 years old then worth calling a Service Engineer.
Sep 18, 2017 | Ovens
AEG Competence B3101-4m oven not working on fan setting. Fan operates but no heat. Also intermittent problem on full grill setting. Any ideas?
Several possibilites come to mind.
first Has this AEG two fans if yes , it has a top and back fan, the element on the back fan sounds like its either a bad connection or blown needs further investigation, the intermittent grill possibly a thermistat, of poor contact on a connection again. Rear and top panel access, you may have to remove the top fan.
Hope this has been helpful
May 31, 2011 | Electrolux Ovens
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
The bottom oven has stopped heating up. In fan mode and oven mode it does not operate. The grill in the bottom oven still works.
It is probably the oven fan element that has failed.
It is located at the rear of the oven compartment behind a removeable cover.
I am basing my solution on the basis that the oven is electrically heated, and not by gas.
Feb 23, 2010 | AEG D5701-4 Electric Double Oven
AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Feb 05, 2010 | AEG Ovens
Oven is AEG Competence, single oven, fan assisted, 4 yrs old. Oven doesn't heat. Light ok, automatic cooking settings not switched on, grill working
If the fan is working o/k, then you need to replace the oven element.
This is located at the rear of the oven compartment, behind a removeable cover.
This should solve the prob.
Please leave feed back.
Jan 06, 2010 | AEG Ovens
Aeg oven d4100 cutting out
There is a cooling fan in the cabinet of the oven which is not working either the fan is faulty or the controling cut in stat is, The fan should run when the grill is selected if does not it is more likely to be the fan/motor at fault.
Dec 07, 2009 | AEG D2100-4 Electric Double Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Ovens Logo
306 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
