Question about D-Link DI 514 Wireless Router (DI-514)
My dlink router is not connecting the internet while giving the limited connectivity error whereas the dsl modem is working fine and router is also indicating all fine. the error is 'could not connect to primary DNS server. your network adapter might be preventing it'. if the ethernet cable is directly inserted in the laptop, the internet works fine. help!
    Habit-Forming:
    Scholar:
  • D-Link Expert
  • 84 Answers
This problems is occur due to Change gate way or ip .
Please follow these some steps to solve your problem:
1- Restart Your Modem Wait for 30 Seconds Than Restart Your Router And Wait 1 min Than Restart Your Computer And Wait 2 min
2- Now Go Back to Your internet Connection Bar And See if You Can Connect Your System with your Dlink Wireless Router.
If your is still then you change the router setting to default .
Don't You Worry if these Steps Do Not work We have Some Major Steps You Might Wanna Perform Before You Gave Up On Your Dlink wireless Router
Fix link Wireless Stopped Working All Of Sudden Tech Vaidya
Posted on Aug 16, 2018
    President:
  • 1,768 Answers
my dlink router is not - moz-screenshot-1.png1. Login to router first and verify that the router status via the rj45 cable (ethernet).
Posted on Aug 07, 2010
I have Dlink 2750u modem *** router. I am switching on Hathway ISP. They give DSL connection modem. How to use Dlink 2750?
Use an Ethernet cable to connect from the port on the DSL modem to the WAN/Internet port on the D-Link modem.
Apr 23, 2014 | D-Link Computers & Internet
I have a d-link router for my laptop and my wireless has worked fine until abotu a month ago my wireless just stopped working, it says that i have full strength connection like all the bars are showing...
this is a DSL router I think
Try pulling the power to the DSL Dlink wi fi router.
For 30 seconds then plug in back in and switch it on again.
If you have a DSL modem attached to the Dlink wi fi device then down power the DSL modem and wait 30 seconds and repower it up. Wait 5 minutes for it to resync with the dsl on the phone line.
As a side note
Have you had the DSL upgraded like from dsl -1 to DSL -2 if yes then check the dsl filter on the phone line sockets can handle DSL - 2
Diagnostics
go to the P.C windows o/s I hope .
Go to command prompt
ping the routers ip address
10.0.0.1 or 192.168.0.1 is the most likely ip address
type in ipconfig
press enter
what is the default gateway (this is the router ip address)
Type in tracert www.google.com
press enter
Can you resolve the DNS name . and get an ip address
if no then DNS server issue check DNS server settings are they on AUTO . in modem or DSL router .
See if the IP hops get to the modem or to the ISP .
May 13, 2017 | D-Link (DI-784) Wireless Router
I can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these...
you should type in 192.168.0.1.
In your request you have:
i can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these componets are hardwired to cannot.has worked fine for years but stopped suddenly!!!!!!!!!!!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 11, 2010 | D-Link AirPlus DI-524 Wireless Router
I have a Westell DSL modem & a D-Link DIR-625 wireless router. Everything has worked fine for years but a few days ago the Internet connection went down. I contacted AT&T for support. During the...
you need to configure the dsl modem to be on bridge mode after you did it successfully. that is the time you configure your d-link for you to connect to the internet.
call first your ISP to configure the modem to Bridge mode after that call your manufacturer of the dlink for them to configure your connection
Jun 11, 2010 | D-Link DIR-625 (790069292637) Wireless...
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Apr 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I can access internet direct. But no internet Model dir 615
Whilst the router is turned on, try to reset the router by pressing and holding the tiny reset button at the back of our dlink router using a paperclip. Then try again.
Jan 02, 2010 | D-Link Computers & Internet
Internet connection fails through DLink router
Some ISPs (Internet Service Providers) require that you "register" the 'MAC' (not an Apple --> Media Acquisition Control) address of the network-adapter of your computer (or router) with the ISP,
before the ISP will allow your computer (or router) to be provisioned.
Your router has a different MAC-address than your computer.
So, your computer works with its "registered" MAC-address,
but your router cannot connect with its "unregistered" MAC-address.
Access the web-server inside the router, and click the 'Clone MAC-address' button, and restart the router.
Then, the router will send the MAC-address of your computer, rather than its own MAC-address, to your ISP.
Dec 31, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Dlink 2640b cannot get both internet and dsl to work together
Unplug both devices,and remove the cable/dsl line input to modem, wait 5 minutes, plug cable back it, then turn on modem, wait a minute, then plug in router.The signals should mesh.If not, buy a new router, theyre cheap!~
Dec 14, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
D-Link DI 514 Wireless Router (DI-514) Logo
214 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
