Question about Sport & Outdoor - Others
I need to change the bearing in the front but cant figure out how to get them off so i can change them
  • 10,865 Answers
Hi. You have definitely come to the right place for assistance. Please get back with the year, model and make of the item you are hoping to change the bearing on. The more details you give, the better we will be able to assist you. Joe
Posted on Aug 07, 2010
Can anyone fill me in (in detail) on how to replace my front wheel bearings in my 2000 xterra? its 4 wheel drive and both fronts are bad.. also i cant figure the size of the caliper bolts out so that info...
Hit up www.nicoclub.com/FSM/xterra/2000/
That's the factory service manual which will provide detailed information.
There's an inner and outer bearing on each side
Sep 18, 2011 | 2000 Nissan Xterra
I have a 97 rav4 and just changed all wheel bearing, front and back. However, i hear this humming sound everytime I drive and the mechanic is telling me that I need to change the rear wheel bearing. But...
have someone drive you vehicle and you sit in the back seat if its a wheel bearing you will hear it and it could also be the tranny as they like to humm
Sep 27, 2017 | 1997 Toyota RAV4
I have a front loading unit model #fwtr6476hso. i have taken the back off it and am pretty sure its the bearing in the tank part of the washer. i cant figure out how to get the wheel off the back to get at...
you need a bearing puller to remove the pulley,
ken5033140k-mxdx2023mm15jplnf4busrnw-3-0.jpg huck the 3 lips on the outer of the pulley hub and tighten the bolt on the puller but not to fast nice and slowly and it will come off.
Aug 02, 2017 | Frigidaire ATF6000ES Front Load Washer
Rumbling noise on front of saturn ion car
Sounds Like A Wheel Bearing Has Failed. ISOLATE it & Replace it
Sep 08, 2009 | 2004 Saturn ION
Front bearings need to be replced
you must change the whole hub assm. they are sealed bearings that cant be changed by themselves.
Jun 26, 2009 | Ford Mustang Cars & Trucks
Got a high pitch squeel .
Jack the front of the car up then spin the wheels this will give you alot better idea of where this noise is coming from. Check the brakes agian and the wheel bearings.
May 17, 2009 | 1998 Ford Ranger SuperCab
Diagram of front hub assembly for 1994 mercury sable.
Best solution to your problem is going ot the junk yard asking them for a left front knuckle. They will charge you about the same price for all this stuff as the auto parts store will charge you for a wheel bearing. After you have this knuckle you will be able to take a few things off of it and be able to put it on with only remvoing like 3-5 bolts.
May 17, 2009 | 1994 Mercury Sable
Clicking noise coming from front right tire on a '01 Dodge Ram
as long as your sure its comeing from the front right tire proceed
to get to the bearing you have to take the wheel off first, rotate the rotor to see if you can hear the bearing.
remove wheel remove brakes/caliper/caliper bracket/rotor remove cotter pin/axle nut remove 4 bolts from wheel bearing assy unplug electrical connector for ABS, if has it tap axle end lightly to dislodge fron wheel bearing assy may need pry bar and hammer or air chisel to remove wheel bearing assy from vehicle clean orifice well and installation is the opposite to inspect the bearings take it out , and look for loose or stuck bearings, if it rolls freely chances are its not bad. . if water or dirt gets inside it can ruin the bearing. make sure you pack the bearing with grease. if the bearing is bad just buy a new one. i cant guarantee it is a bearing so good luck.
Mar 23, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
