Question about Dryers
My outdoor dryer vent leaves about a gallon of lent out on my patio and cedar storage unit every season. How do I trap the extra lint coming out the vent? I have tried cheesecloth, but I have to change it daily which is very inconvenient. I am meticulous about cleaning the machine lint trap after every load. I avoid dryer sheets whenever possible. PLease help.
  • 1 more comment
  • Grangoose May 30, 2008
    I have the same problem. Must be some creative person out there that can help us solve this problem.
  • larkinhome Jul 22, 2008
    I have the same problem but worse. The designer of my house has the dryer vent exhaust directed into the outside condensor coil of my air conditioning unit. The exhaust is less than three feet away and when the dryer and air conditioner are both on, I have a lint and heat problem. Any suggestions from the gurus? Please let me know. Thanks!
  • lndrylady Apr 15, 2009
    Bought Samsung electric dryer. No venting pipes that lead outside. Best Buy tech attached vent kit to back of dryer and it leads into plastic container with water in it to catch the lent, the coil attached to to dryer goes over the water hoses and the container is sitting on our water heater. The hoses attached to the washer started to burn and melt! Had to turn off washer, they are coming out to replace hoses. How should I vent the dryer or tell the tech to so this fire hazard doesn't happen again. Thanks
  • 78 Answers
I'm sorry, but that happens with all dryer vents. you might consider rerouting the vent to another location. while you're at it the vent hose needs to be cleaned out, they tend to clog up and decrease drying efficiancy.
Posted on May 03, 2008
Why is clothes dryer heating, but not drying?
Be sure to check the lint trap in the front and also the lint vent in the back. That is the big hose in the back of your dryer. Take it off and then ensure a bunch of lint isnt stuck. Empty in trash cans. Also you can get a lent vent cleaner which is a long pole to clean vents on the roof and also in the hose and pipes. This is important to clean at least quarterly to avoid any possible fires.
Aug 28, 2014 | Dryers
O.k. If it does not have a lent trap where does the lent go ?
The lint will build up in your ventilation tube very rapidly and become a fire hazard. It will also get all over the wiring inside of your dryer and cause shorts. This will happen anyway but over a length of time. Bottom line...keep your lint trap in, clean it regularly, an stay on top of cleaning your vent line as well.
Sep 21, 2012 | Kenmore 22422 Top Load Washer
The lint trap on my GE dryer is moist.
Check the venting, if it is blocked or if the venting is bend it will not allow the moisture to leave the dryer and it will end up in the lint trap and on the door
Jul 26, 2012 | Maytag Neptune MDG5500AW Gas Dryer
I have a kenmore elite model 110.8586 or 8587 anyway I cleaned my lent screen put it back as I always do after every load and know it say check lint screen
Possibilities
The sensor is dirty..remove the lint trap and clean the orifice with a Swiffer duster. Dryer sheets can clog the lint trap use a tooth brush and detergent to clean the lint trap. Alternately see if it presents the same issue operating it without the lint trap. If you have an air compressor blow out the slot too. Make sure the main exit hose is cleared also *vent duct*. Tip the unit and blow the air in too.
Or a melting type fuse mounts on the blower housing and is tied into the same circuit as the door switch. When it melts it shuts down everything and this keeps the lint from catching fire.
Also check the belts.
You can turn off the beeping if you would like. Instructions are in the manual. By Pressing the buzzer button it has Loud medium low and off positions.
Remove the rear vent and try the unit...
I'm thinking that your sensor is probably the issue here.
Jun 10, 2011 | Kenmore Dryers
I have a Maytag Dryer that stopped in the middle of a cycle and there is no lent at all and the dryer will not come back on..
Possibly a blown thermal fuse. May have to call repair man. Pull bottom panel and ohm our thermal fuse, just behind blower, lint trap assy. Also, check for clogged vent. This sometimes causes the thermal fuse to blow.
Aug 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is heating up but it takes a long time to dry.
If the clothes are coming out wet and hot after the first cycle then there is a blockage in the exhaust. This blockage could be at the lint trap or at the exhaust tube leaving from the back of the dryer. You need to check the lint filter area by removing the lint filter and with a flashlight look into the area where the lint filter was to see if there is any build up of lint. If so, you will need to clean this area. Also at the back of the dryer there is a hose that comes from the dryer to an outlet to the out side. This hose could be clogged with lint or possibly kinked to where the proper amount of air flow is not allowed to leave the dryer therefore causing the clothes to have to dry longer. Check these two areas first before going any further due to these checks are simple and may solve the problem.
Good luck hope this helped
Dave
Mar 30, 2010 | GE DVLR223 Dryers
It is taking 3 full cycles to dry my small loads on my Maytag Performa PYE2300AYW. I have cleaned lint tray and trap. I need to clean the lint from the inside of my dryer - How do I do this?
The main area that you have to clean is the pipe leading from the back of your dryer to outdoors. Pull your dryer away from the wall. Unplug it. Unfasten the vent pipe. Now look into the back of the dryer exhaust and remove any lint you see there then look into the vent pipe and remove any lint. Finally go outdoors and remove any lint you see in the pipe or the pipe grill/cover.
Jun 04, 2009 | Maytag PYE2300AY Electric Dryer
Dryer is not drying
Had the same problem. Take the back of the dryer off and vacuum were your lint trap is installed at. Once you take that plate off you will see the lint build up and you will be able to clean it properly.
Apr 14, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore he2 electric dryer
The lent sensor is either dirty or is bad. It could also be the control board that is faulty as well. Unless you know electronics and have the proper testing tools, I would recommend calling a service professional. Hope this helps and that you have a fantastic weekend.
Apr 11, 2009 | Kenmore Dryers
Lint Trap in dryer
Friend,
ngfam1 At your service!
You said, lint is collecting by vent located outdoors. And you feel, the lint trip isn't working.
and you feel very concerned that this is a fire hazard.
We do clean the lint trip off before every dryer run.
The fact that lint is clogging your outside vent does not mean the dryer is not working properly!
The dryers with the top mount lint screens have blow by lint to the outside.
My next dryer will be a Speed Queen dryer which has the lint screen inside the dryer by the door and works better , without the mess on top of the dryer every time I remove it to clean before each load!
That top filter is an old style design!
The outside screen is to keep small animals out!
I find the new plastic outer vents have a plastic mesh screen which caused the same issue as you spoke of and caused my dryer to stop getting hot even though it was only half blocked outside !
I REMOVED the screen and left it off!
And recommend this to all other folks too!
The dryer is too hot for animals to want to enter! They sense it! AND THEY WON'T go in it!!
There are a few types.
1.The old ones are a aluminum vent with a aluminum flap like door that has a spring to keep it closed when the dryer is not on and forcing it open to allow for the exhaust to escape.
2. The newer ones can have a plastic flap that works the same way ,but usually designed without the spring mechanism.
3. the newest one are the ones with the plastic mesh screen that I spoke of above!
Remove the pop off plastic screen and leave it off!
Or if you have the flap door kind.
Change the vent to the open one that comes with the plastic pop on mesh and do not put the screen on!!
It's been years that mine is off and it's all is fine.
You will be fine
Bless You ,
huuum
Please give me the best rating for this solved solution!
Thank You!
Sep 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
2,058 people viewed this question
Top Dryers Experts
