Question about Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive
I have windows 7 and a seagate freeagent extreme 1TB external disk. Worked fine until now. Suddenly disconnected and is not recognized by Windows anymore. Tryed swiching computer off and on, disk on and off, changing cable, changing USB port and nothing helps. The OS does not recognoze the disk.
    Sergeant:
  • 203 Answers
Hi, please anyone feel free to register on the site that the link takes you to so you can see the thread, it shows a link from You Tube on how to take the Seagate apart so anyone with the problem with the unit just making beep sounds and not being reconized by their P.C.
As all the threads i saw like my 1st thread reporting about my friends Seagate FreeAgent Desk 500GB asking about his problem and no-one was getting replies, and they where getting frustrated, I decided to find out. Someone has replied to my other thread with the same answer as taking it apart and connecting it to a P.C. So to help others who need their important files from the external HardDrive I have made a step by step guide so even novice P.C. users like myself can attempt to sort it out without being charged loads $-£ etc.. It seems unfair for all these users to buy something new and with in 1 week - 2 months it fails and they have important files etc.. stuck on the HardDrive and being charge to retrieve it. I'm not looking to cause any trouble just want to help others out. http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t​=84 You will find the thread in 'Technical ' under 'General Technical Issues ' please let me know how you get on thanks.
Posted on Aug 17, 2010
My seagate freeagent goflex 1tb hdd appearing as local disk in my computer... the autoplay dialog window doesn't come up when the drive is connected..
AUTO PLAY DIALOGUE IS OFF IN YOUR OPERATING SYSTEM
ENABLE AUTO PLAY
WHAT OS YOU ARE USING
OR CHECK BELOW LINKS
Windows 7, Windows Server 2008, Windows Vista, Windows Server 2003,or Windows XP
Fix it for meTo disable or enable Autorun automatically, click the appropriate Fix this problem link. Then, click Run in the File Downloaddialog box and follow the steps in this wizard.
Disable AutorunEnable Autorun
Fix this problem
Fix this problem
Oct 29, 2013 | Seagate FreeAgent GoFlex Desk - 1 TB...
Windows xp will not recognise the seagate freeagent desktop drive
Assuming you have tried other usb ports and had no change,remove the usb connection, then go back into device manager and select the usb controller, right click and select delete as this will erase any input driver the usb port recognises. Restart the pc and then the controller should be reinstalled automatically as it sounds as though the controller has become corrupt for some reason. Go back into device manager and check there are no exclamation marks, reconnect the drive and see if it's recognised.
Oct 05, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.
Claire,
Have you tried connecting the drive to another computer using Windows 7 or later. You could try chkdisk /f at a command prompt or get the testdisk app to identify deeper issues with the drive.
Chappo07
Oct 24, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Seagate 1TB FreeAgent external Harddrive is not working on my laptop which is running on XP. In Manage Hardware section this device is shoing as unknown hardware.
go here
And download for windows. You see most companies like you to download the software from their website for older operating systems for your computer to recognize it.
Thanks, Cody
Sep 11, 2012 | Seagate Freeagent Go 1 TB Hard Drive
Leds Flashing white Windows ask for driver It was
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps you
Aug 28, 2011 | Seagate FreeAgent Go 1TB to USB 2.0...
Seagate freeagent USB hard drive power is not showing. Adaptor is ok.
if windows then go to
Start->, select My Computer, and rightclick, and choose Manage.
now on the left there is disk manager - click it. if the disk is on the list it is working and might just need to be formatet or activated.
Disk Manager: http://www.partition-tool.com/images/resource/windows-7-disk-management2-b.gif
Mar 26, 2011 | Seagate FreeAgent Pro 1TB External USB...
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My computer can't detect my external harddrive..
connect the drive, go to disk management and check if the drive is there. change the disk letter.
Jun 23, 2009 | Seagate FreeAgent Pro 1TB External USB...
Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
Jun 19, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive Logo
272 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
