Question about Motorola Talkabout FR60 (14 Channels) 2-Way Radio
I have a pair of FR60 Talkabouts. I have not used them in a few years. After putting in fresh batteries, one is fine. The other is indicating "low battery" by the red flashing light next to the on/off/volume control switch and giving the characteristic double beep after depressing talk or call. I have tried two different sets of fresh batteries and know that batteries aren't the problem. I would welcome suggestions for fixing this problem. Greg Helms, Linthicum, MD
    President:
  • 2,761 Answers
There's a good chance that your problem is due to corrosion buildup on the radio's battery contacts. Even if you can't see and buildup, wipe the contacts firmly with dry cloth, the reinsert the batteries and try the set again. If you can see a heavy buildup on the contacts, you may need to clean them with a fine wire brush, steel wool, or fine sandpaper. Be sure to remove any residue from the cleaning before you install the batteries.
Bill B
Posted on Aug 07, 2010
Garmin fr60 footpod
Read this BEFORE you buy a new Garmin footpod because of non-detection issues after replacing batttery.
My battery died and after changing it with a new one I've not been able to detect the footpod with my 910xt until now. I notice that in the cap or lid of the footpod where the battery sits before closing it sits a white piece with contacts for the battery. I had inadvertently taken this out when replacing the battery, which is fine BUT you have to put it back in a certain position. If you look very closely at the cap where the battery sits you will notice there are tiny grooves where the contacts should sit into. As soon as I line these up with the white contact piece, voila! Footpod was immediately detected. Try it if you are having issues after replacing a new battery.
Aug 28, 2012 | Garmin Forerunner 50
JUST PURCHASED NEW CAMERA, PUT NEW BATTERIES IN AND AFTER TAKING JUST A FEW PICS, BATTERY LOW INDICATOR CAME ON AND SAYS IT NEEDS NEW BATTERIES. PUT NEW ONES IN AND AGAIN, BATTERY LOW INDICATOR CAME ON. ...
yes, The Flash mode consumes LOT of power, thats why it needs lot of batteries, use " rechargable batteries", or use camera without FLASH, and use GOOD QUALITY battaries
Jan 22, 2011 | Canon PowerShot SX100 IS Digital Camera
Keep putting new batteries in Nikon Coolpix L11 but keep saying low battery???
Check if the charger is working. If yes Firstly, make absolutely sure that you have a pair of fresh HIGH QUALITY batteries, in fact go and buy a couple of duracells. Digital cameras are notoriously power hungry and it is very possible that a pair of cheap standard batteries will not be able to run it for more than a few minutes. Check that the terminals of the batteries and the camera are clean. If none of this works, and you did have fresh alkalines or equiv. then it will have to be returned for repair.
Thanks.
Jun 18, 2009 | Nikon Coolpix L11 Digital Camera
Even on a fresh battery the low battery indicator is on
The cpu board has failed or is failing. To be specific......a capacitor on the board has failed allowing current to flow when the unit is not in use. I see a new cpu board in your future or new rangefinder.
Dec 28, 2008 | Leupold Wind River RB800C Rangefinder
Low battery indicator
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jun 17, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
FR60 intermittent transmission
Hello snorker,
It could be battery / power issue. Two-way radios draw much more power when transmitting then receiving. If the batteries are weak the radio might work perfectly fine on receive and then cut-out when you depress the Push-To-Talk.
Best Regards,
Ken
Go Ahead. Use Us.
Apr 30, 2008 | Motorola Talkabout FR60 (14 Channels)...
Wont switch on
Some cameras have a bettery setting in the menu. You need to make sure this setting is set to the type of batteries you are using. Usually when you use akaline batteries and even if you put in fresh batteries but still get the low battery indication then your camera is set to rechargable (Ni-Mh). Ni-Mh has more power to it then alkaline so this is why you get the low indication.
Feb 11, 2008 | Samsung S1030 Digital Camera
Battery Low with NiMH (won't turn on) OK with Alkaline
Not the camera obviously - works OK Replace the NiMah batteries- get several sets and keep one set in the bag charged with one set in the camera. You may be able to 'refresh' the original batteries by putting them into a small flashlight and running them until the bulb goes out. This discharges them completely- then recharge. It is said batteries have a 'memory' so that a battery that is down say 50% and recharged will only recharge that 50% and the other 50% is lost for use. So you have to flatten the batteries completely
May 29, 2007 | Samsung Digimax A7 Digital Camera
Low Battery when using screen
Voila fixed.
Oct 21, 2006 | Canon PowerShot G2 Digital Camera
Motorola Talkabout FR60 (14 Channels) 2-Way Radio Logo
163 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
