Question about Love-Less Loveless Ash MU405 Cougar Quiet Warm Ash Vacuum Air Purifier
Discribe your self - Love-Less Loveless Ash MU405 Cougar Quiet Warm Ash Vacuum Air Purifier
    President:
  • 3,773 Answers
Professional and experienced
And damn good looking for 70 +
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 07, 2010
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
www.petco.com/.../Sealand-Replacement-Bulb-for-Green-Killing-...
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
https://www.norlandprod.com/lightsourc.html
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
Dec 10, 2015 | Honeywell Air Purifiers
Does check engine light reset after replacing faulty gas cap.
A check engine light will not clear itself! The light will have to be code read and reset using a OBD code reader.
Feb 26, 2015 | AEM Brute Force Intake 2003-2005 Ford...
Oreck SL will not work on medium setting
Either your switch is not making a contact internally or the wire that runs from the motor to the switch is loose or not connected, or that speed is burned out on the motor. Those motors have a separate wire for each speed, so it's either not getting power to the motor from the switch or the that speed setting is burned out on the motor its self. I would just work around it and use the low or high setting until you can take it apart to test if the motor is getting power from the switch, if so then the motor is bad, usually the bearings go out on the motors before the wiring does. Unless your motor was on medium and was stopped for a long period and overheated that setting which will melt the wires and cause it to not work. They have a safety switch on the motors now to keep this from happening.
Jan 12, 2015 | Oreck XL Professional Air Purifier
+where can I get parts for my lonic Breeze Quadra Silent Air Purifier #S1637
Easier to purchase a new unit. These are a real pain to take apart
Dec 09, 2014 | Air Air Purifiers
How can I get a airfilter for a Ariens model 911077
Generally you can get away with a different brand that shares the component. Just take in the old one to compare when you purchase. They need to be the same size.
Jul 19, 2014 | Filter Queen Defender Air Purifier
Heat pure 1500 shuts down and displays 90.
over heating its self, it could be a blocked and not getting the right air flow or the sensor for the heat control is on its way out. check the filter if this model has one remove all dust from the intake, check that the fan is working, if the motor has been making any buzzing or funny sounds this can be the problem too. buzzing is the starter motor humming or clicking the motor is failing.
Mar 23, 2014 | Advanced Tech Infrared Heat Pure 1500 -...
Hi i have a Ecoquest Breeze AT Living Air
that ligth its uv lamp you can replace it your self get parts from ecoquest for the rigth model
Apr 02, 2010 | Ecoquest Breeze AT Living Air Purifier
Hi my old Honeywell 13520 has acquired a periodic squeal. I am sure it is a motor issue. Any way to tune up these little motors? (Brushes, etc..)
Usually if the motor is squealing, the bearings are dry no lubrication and worn. If you have oil ports you can oil it and quiet it down for a while. Most motors now have self lubricated or oil impregnated bearings, which you can't lubricate. It costs as much for somebody to replace the bearings, as it does for a new motor. Most people replace the motor.
Nov 17, 2009 | Honeywell Enviracaire 13520 Air Purifier
PROBLEM WITH BREEZE AT
It sounds like the fan motor may need to be oiled, front and rear. That has been my experience with stopping and starting at that length of interval.
Jul 26, 2008 | Ecoquest Breeze AT Living Air Purifier
Making a constant clicking noise
Clicking usually corresponds to some circuit trying to power up, but being shorted and having to trip. It clicks more than once because it tries to self-reset. Some fiber or mineral contaminant might have messed things up; get it outta there.
Apr 01, 2008 | Brookstone Pure-Ion UV Air Purifier
Air Purifiers Logo
44 people viewed this question
Top Love-Less Air Purifiers Experts
Adolphus Roberts
Adolphus Roberts
Tom Reynolds
Tom Reynolds
Margaret Anstett
Margaret Anstett
Level 1 Expert
Are you a Love-Less Air Purifier Expert? Answer questions, earn points and help others
